Old 10-11-2002, 02:16 AM
91civicDXdude's Avatar
d16z6 swap header install Q...
when i did my d16z6 swap, if i remember correctly, i had to cut the mounting bracket off of the d16z6 stock exhaust manifold as it was not in the same location as my stock dx motor. If i was to buy a header which im planning as my next mod, would i have to cut off the original mounting bracket and weld on a new one?
Old 10-11-2002, 07:44 AM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
I ran a 92+ header on a couple different engines and left the bracket disconnected since it didnt line up. I did this for awhile and had no problems. if you're comfortable doing that....go for it, if not, you'll have to cut and weld....good luck
SOLD!
Old 10-11-2002, 08:03 AM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
I didnt change anythigng when i swapped my D16.i think i used the91 mount from the block to the header, but only 1 hole lined up.
gunnmen01
My other ride..... is YOUR MOM !!!!!!
ZC or D16Z6 swap in a 91 Civic Si cspu Engineering/ Technical 3 04-07-2012 09:51 PM
95 d16z6 into 91 crx si eray_92 How-To's and Walk-Through's 0 08-31-2010 04:24 PM
93 D16Z6 swap into 91 CRX SI, Need help riptech7 How-To's and Walk-Through's 2 01-08-2010 07:48 PM
91 SI ,D16z6 swap HELP!! Josh95cx '88 - '91 Civic | CRX | Wagon | Shuttlee 4 01-27-2003 11:50 AM
d16z6 swap info 91civicDXdude '88 - '91 Civic | CRX | Wagon | Shuttlee 2 09-03-2002 11:49 PM
