Old 08-22-2002, 09:37 PM
Josh95cx Josh95cx is offline
91 SI ,D16z6 swap HELP!!
Can someone please clear up somequestions for me. First thanx for any help you can give me. My friend has a d16z6 that he got from a junkyard with no distrib. He put his old d16z6 distrib on it and it ran for 45 mins and just shut off, but no check engine codes. Is this motor still good it turns over but no start. can i just use my SI intake and distrib, and it work with my si tranny? which plug wires would i use for it? Also the mechanic that looker at it for him told him it couldbe a electrical problem. Please give me some idea's because he only wants 300 dallors for the motor. I already know about wiring the vtec I am asking would it work in mine. thanx for any help i advance
Old 08-22-2002, 10:24 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
try the cap and rotor first, could be the igniter or even the distributor itself. Yes you can use your si intake, yes our si tranny will bolt up. You can use your si distributor with a few modifications..... try this link and go to http://hybrid.honda-perf.org/tech/info.html. once your there go to archive,4g tech that will take you right to the swap........
good luck....gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 08-23-2002, 11:47 AM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
welcome back gunnmen01! i assume login issues over?
here are the links i generally give out for the sohc vtec swap:
http://www.geocities.com/bing_bong916/vtec.html
http://hybrid2.honda-perf.org/tech/sohcvtec.html
http://www.geocities.com/kurtsi_on/page7.html
http://www.geocities.com/crx288/d16z6swap.html
http://www.angelfire.com/ca/DrOhm/hybrid.html
http://integra.vtec.net/engine/vcontrol.html
you can use your Si dist., ecu, and intake mani....but you'll need to get an rpm activated switch. or get the p28 ecu (92-95 Si/EX) and the distro. fixes gunnmen suggested.
the fuel mapping and what-not is slightly different when running the d16a6 (4th gen Si) stuff. you actually loose a couple of horses...like 3-ish. to some people that makes all the difference. having to buy a z6 distro & ecu will cost more...to others that is the difference.
you use plug wires for whatever distro. you use. either a6 or z6.
your a6 Si tranny will work perfectly.
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 01-27-2003, 08:02 AM
Civic Jim's Avatar
Civic Jim Civic Jim is offline
Send a message via AIM to Civic Jim Send a message via MSN to Civic Jim
hey looks like your new to the forum hope the work turns out OK
check ya later
Jim - Your Resident EDM Biatch
B16A1 I/H/E
4TH GEN UK SITE
Honda Civic EE9 1.6-i VT
Old 01-27-2003, 11:50 AM
amy@af's Avatar
holy manoly...how did this one come back up 5 months later???
1995 olds achieva engine swap help. handymann3 Achieva 2 01-21-2010 09:26 PM
93 D16Z6 swap into 91 CRX SI, Need help riptech7 How-To's and Walk-Through's 2 01-08-2010 07:48 PM
D16Z6 swap in 91 crx si HELP?prices up for work done Bori '88 - '91 Civic | CRX | Wagon | Shuttlee 9 04-03-2004 08:05 PM
help with D16Z6 swap.... bambam89lx '88 - '91 Civic | CRX | Wagon | Shuttlee 9 06-10-2003 01:44 PM
89 civic swap d16z6 please help sabrina800 '88 - '91 Civic | CRX | Wagon | Shuttlee 0 06-04-2003 09:42 AM
