Old 10-10-2002, 03:29 AM
Veetec's Avatar
Veetec Veetec is offline
Send a message via ICQ to Veetec Send a message via AIM to Veetec
Lsd?
What are the pros and cons of using a LSD? Which other parts do I need to install it and use it properly (new clutch?)? How long do you need to install it? Is it worth to install it on a stock (engine) 5th gen? Do I have to adjust it somehow? Is there anything else I should know about it?
Sorry for all the questions but I´m really interested in getting one.
Thanx in advance!
Old 10-11-2002, 06:34 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
ive never heard any cons of using a lsd, only good stuff. i forget what it was, but something like when your taking out the stock differential, there something in there that will probably break when you take it out with the differential, so you need a new one. you dont need a new clutch. i would suggest taking your tranny down to a shop to ahve it done. if your talking about putting it in a stock engine prelude, then go for it, cause h22's are sweet so yeah. its always better to have both tires grip than just one. you wont need to adjust anything.
Old 10-13-2002, 05:13 PM
Veetec's Avatar
Thanx a lot for your help! I´m a bit broke in the moment but when I got some money again I might get one.
LSD in d16z6 transmission sohcd16beast JDM Motor & Parts info/chat 0 07-31-2010 03:10 PM
how to tell lsd from non lsd integra111 JDM Motor & Parts info/chat 11 08-22-2004 09:48 PM
Difference: LsD SiR & Non LsD SiR... B1SiR6A Let's get Technical! 3 04-01-2004 06:02 PM
b16a lsd vs b16a non lsd 91blublaze Engineering/ Technical 16 10-14-2003 03:20 PM
Does anyone have a quaife LSD installed on their lude?? justin@af General Discussion 2 03-25-2002 12:09 PM
