Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 10-06-2002, 05:49 PM
sosicracing1 sosicracing1 is offline
Question reverse problem
I seem to be having problems putting my car into reverse. It feels like its in gear but when i go to lift the clutch and apply gas it grinds the gear sometime i have to take it out of gear and put in a few times before i can get it to go. Does anyone have the same problem and if so any idea whats causing it. Your opinions are appreciated.
Greg "02" spec-v
Old 10-06-2002, 11:48 PM
ss racer ss racer is offline
Dont worry its not you its the car. I have already taken mine in to the dealership to see what was up. They said thats just how it is. If it happens just throw it into another gear and try again. Try 1st to 2nd then throw it into reverse. SHould work fine.
Old 10-07-2002, 12:09 PM
muphasta muphasta is offline
Send a message via AIM to muphasta
Happens to me at least once a week as well. I am tired of it! I am wondering if I should change the tranny fluid early, because of the grinding of that reverse gear?
Old 10-07-2002, 12:17 PM
SilverSpec-V SilverSpec-V is offline
would a short shifter fix this problem? I kno the short shifters clicks into place each time you shift without a short hesitation between each gear, unlike the factory clutches. Maybe that would guarantee the proper engagement of that reverse gear??!!
Don't brag, never brag about yourself.
Old 10-07-2002, 12:49 PM
pinyoot4you pinyoot4you is offline
i don't think the shifter is the problem, it's the synchros of the gearbox that needs fixing
Joel S.
SE-R Spec V modded with:
AEM CAI, Progress lowering springs, Carbon Fiber Hood (on its way)
Old 10-07-2002, 12:52 PM
i have the same problem as well, if you pay attention closely, you can totally feel that it's not fully in gear.... so what you do is before you grind, put it back to neutral, step the clutch all the way in, and put it back in reverse.....if you feel it again, repeat the process again, it usually takes one or two times before it gets back in gear
Joel S.
Old 10-07-2002, 03:30 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
I know what your talking about isn't completely normal, but alot of it is. They engineer the tranny so it won't just slip into reverse, it is supposed to be kinda difficult, same with 1st gear. The reason being you NEVER want to go into reverse while driving, so the harder it is to get in the better, the same kinda goes for 1st, you don't want to go into it unless youre going <10mph or youll mess some stuff up. So if it's hard to get in either of those gears, don't automatically assume that means the tranny is defective, more often than not its just difficult because its made to be difficult so you don't accidently screw something up
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 10-07-2002, 08:48 PM
hinggu hinggu is offline
as far as i know, all cars don't really have synchrons for reverse. what i always do for the reverse is to put it in first gear first and then put it inot reverse
Friends Don't Let Friends Drive Stock-K&S Racing Development
www.kandsracing.com
AEM CAI
Custom Apex-i N1 cat back
Reverse gear out!! JayRider33 Monte Carlo 2 11-04-2010 12:31 AM
Xterra 2005 reverse problem neolitico Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 0 10-11-2009 07:40 AM
Gotta Reverse Problem!! MX6Chick MX-6 2 05-29-2004 09:47 AM
reverse problem spv387 Classic Cars 0 10-29-2003 10:46 PM
86' Accord Reverse Problems GundamExpo Accord/TSX/Accord Hybrid 2 10-20-2003 11:29 PM
