Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 11-02-2010, 11:41 AM
JayRider33 JayRider33 is offline
Reverse gear out!!
I have a 96monte carlo ls 3.1 and the trans was slippina few times and I added Lucas transfix to it. Now it just stopped going in reverse but all the other gears work. I was thinking about a trans flush and ew filter but Im not sure if that will solve it. Im trying to see if i can fix it withut a rebuild because if i have to rebuild the tranny il jts have to scrap it.
Old 11-02-2010, 02:32 PM
maxwedge maxwedge is offline
A990 racer
Re: Reverse gear out!!
No reverse is internal failure, no way to fix this without a major repair.
Old 11-04-2010, 12:31 AM
Blue Bowtie's Avatar
Registered Offender
The one possibility is to check the reverse servo from the outside. The servo cover can be removed and the servo piston and seals can be removed and inspected.
It may also be possible to verify that the reverse band is holding the input drum or if the band or anchor are damaged. A line pressure test and scan should reveal whether the reverse solenoid is operating, and that the valves are complying.
You'll have to determine if the vehicle is worth the diagnostic time.
New owner with reverse gear problem mikesbigbox 3000GT/Stealth 13 09-19-2004 02:49 PM
Engine cutting out when reverse gear selected twomey_paul Escort 1 10-14-2003 02:33 PM
fastest car in reverse gear!! ragt20 COMPLETELY off-topic 10 01-31-2003 10:28 PM
Reverse gear problem mipinc Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 0 06-27-2002 10:29 AM
Idles rough in reverse gear vikon Maintenance 11 10-14-2001 03:47 PM
Tags
problem , reverse , trans , transmission
