Old 10-04-2002, 05:56 PM
kicker1_solo's Avatar
kicker1_solo kicker1_solo is offline
Send a message via AIM to kicker1_solo Send a message via Yahoo to kicker1_solo
I need quick help....
88 honda accord
when I'm driving, forward or backward, every gear. I hear this scraping noise. It just started yesterday morning, first time it's rained here. It scrapes even louder when I use my brakes. I take the wheel off and see this
the shiny area around the caliper is where I think something is scraping, like a rock or something.
see all that shiny stuff, that's little metal dust particals.
So I think there's a rock stuck in the brake part and is scraping all the time and even worse when I brake. So....how do I fix it? And quick before I go pick my gurl up from work in 30 minutes. Thank you
2000 BMW 323IT
1954 Ford F100
With every post my penis grows smaller
Yakima Valley Truck Club Yakima Washington
Old 10-04-2002, 06:05 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Uh, sounds like you need to change your brake pads?
Exact same thing when mine were down to bare metal, but when I checked my outer pad, there was plenty of material left, but it was the inner one that was totally worn down.
DVSNCYNIKL's Avatar
DVSNCYNIKL DVSNCYNIKL is offline
R.I.P. DAD 3/25/11
Send a message via ICQ to DVSNCYNIKL Send a message via AIM to DVSNCYNIKL Send a message via Yahoo to DVSNCYNIKL
It looks like your break caliper may be loose dude. Are u sure it isn't loose?
Why do banks charge you a "non-sufficient funds fee" on money they already know you don't have?
Old 10-04-2002, 06:08 PM
I don't think it's loose, but it might be.
someone else told me that the brake pad is probably warn too.
I've had this problem before in my civic, but it was only when I went in reverse. My mom took it to les schwab for me last year, they took the wheel off, and found a little red rock stuck in there. They took that out and it was fine. It happened again, and they took the wheel off and it just fell out. I took the wheel off and looked around, couldn't see anything, put it back on and it still sounds like my bed when my gurl is over.
2000 BMW 323IT
1954 Ford F100
Old 10-04-2002, 06:13 PM
Jay! Jay! is offline
Horizontally Opposed
It's probably time for a brake job. They typically put a little metal tab inside the brake pad so that when it wears down to 10% (or whatever) the tab scrapes the rotor and that's your "low brake pad" warning sound.
Hierarchy of Subaru:
(Click to see mine!)
Old 10-04-2002, 06:34 PM
alright, I just went to get my gurl from work. It did it most of the way there and to her house. Then on the way to my house it didn't do it at all, not even when I was braking. Then it did it once for a second and then stopped again. Would warn brake pads do that, cut in and out like that?
2000 BMW 323IT
1954 Ford F100
Old 10-04-2002, 07:06 PM
Alright, how much are brake pads, where can I get them, and can I put them on myself?
2000 BMW 323IT
1954 Ford F100
Old 10-04-2002, 07:15 PM
ci5ic's Avatar
Dude. Brake pads are hella easy:
Basically, go to any Schucks, Napa, whatever and buy the brake-pads (you can get them as cheap as like $20 or so for the set).
Then, pull off your caliper.
Remove the old pads, hang onto the shims and metal clips.
using a large c-clamp, compress the caliper piston back into the housing (you may want to pop the lid on your brake-fluid reservoir, and make sure it isn't too full so it doesn't overflow).
Install the new brake pads with some "disc brake quite" on the backside of the pads and shims.
Put the caliper back on (check your chiltons or whatever for torque settings).
Put the lid back on the reservoir.
Old 10-04-2002, 07:42 PM
ok, I was paniced cause my gurl's dad would get mad at me and blame me for this, even though I can't control it at all. He's only home on the weekends, just found out that he's not gonna be home this weekend. Sweetness, so I'll be doin' that sometime soon. Thanx for the help.
2000 BMW 323IT
1954 Ford F100
Old 10-04-2002, 07:54 PM
ci5ic's Avatar
:huh:
What's he got to do with the brakes on your car?
Old 10-04-2002, 08:01 PM
Originally posted by ci5ic
:huh:
The Accord is his g/f's car.
Old 10-04-2002, 11:37 PM
:huh:
what Jay said
2000 BMW 323IT
1954 Ford F100
Need quick help toyotaman001 Tacoma 0 04-14-2004 01:46 PM
Need quick help with car LancasterWannaBe Integra 3 05-31-2003 03:12 AM
Need Quick Help Please crxlvr '88 - '91 Civic | CRX | Wagon | Shuttlee 8 03-26-2003 06:41 AM
Need quick help Goosse Exterior | bodykits | Lighting 0 02-06-2003 12:58 PM
Need quick help.. how to remove the heater-A/C controls? CharmCity '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 0 09-14-2002 11:13 AM
