Old 10-04-2002, 06:44 AM
CalsonicR34's Avatar
CalsonicR34 CalsonicR34 is offline
Angry Tire Decals : Help
Is there a way to clean the tires and an easier way to apply those tire decals or techniques such as to get them to stick and aligned properly "potenza, bridgestone" ones on the Tamiya race cars. They are awful as they usually dont stick, tear, or come out distorted. I'm dissapointed since i buggered them all up on the Supra, I don't it to happen on the calsonic.
Old 10-04-2002, 06:55 AM
Purpura Delujo Purpura Delujo is offline
I know how you feel! I bought the Calsonic R34 and i only managed to get one whole tire done in decals, then others folded over themselves( because tamiya put them on the backing paper backwards, what a stupid thing to do) and because they have so much glue on them they stick together, well if you get only 3 wheels done i can send you mine! i am going to strip and respray mine as a street racer wide body kit! with no spoiler and better wheels 2-4 big exhaust and paint it.......metallic black?Well good luck!
Old 10-04-2002, 07:10 AM
Jonno's Avatar
Jonno Jonno is offline
Send a message via MSN to Jonno
Those tire decals arn't like normal decals, you take off the piece of paper, then it looks like there is one piece of paper there with decals on it, there is two pieces of paper, on very thin with decals on it, you take the thin piece of paper off, place it where it should go on the tire, top side up, then press it down hard and it should stick, get some water on your finger and dab it over the tire decal, use a damp cloth and make sure that the hole piece of paper (and decal is wet) then the piece of paper should just easily slide off, leaving the decal there. Dab the decal with a damp cloth to make sure it is down properly and *walla*, a nice tire decal. It clearly says this on the instructions.
I have had no problems using this method, maybe you might be doing it wrong
-Holden Berlina Turbo, RB30ET.
-Mitsubishi Legnum VR4
Old 10-04-2002, 07:27 AM
935k3's Avatar
935k3 935k3 is offline
The only thing I can add here is do not let your fingers touch the backside of these, if you do they will not stick.
Start by cleaning tires then apply a coat of water based Acrylic satin on sidewalls only then apply decals , then apply 1 or 2 coats of acrylic flat to seal them in, this thouroughly hides decal film.
Old 10-04-2002, 07:48 AM
Jonno's Avatar
Do exactly what it says, with acrylic, not enamel, (it doesn't dry, I know from experiance)
wide whitewall tires/tire decals El Krammito Car Modeling 5 08-21-2006 08:40 PM
Tamiya tire decal question WasteGas Car Modeling 6 06-15-2005 05:18 AM
TIP:Tamiya Tire Decals builder77 Car Modeling 8 06-03-2005 07:30 AM
MicroSet/Sol use on tire decals Captain Mark Car Modeling 11 03-11-2005 11:39 AM
Tamiya Williams BMW FW24 Tire Decals aznyanksnyc Car Modeling 3 07-30-2003 07:23 PM
