Old 10-02-2002, 12:09 PM
Dudley03 Dudley03 is offline
B18a tranny question
hey i bought my friends 90 integra for 200 bc it was totalled. im taking the engine but its automatic. other than the tranny what other parts do i need to convert it to standard and will my shift linkage work and will the axles fit into my hubs? thanks and by the way i got and std hatch
Old 10-02-2002, 12:12 PM
91zc 91zc is offline
You will need a flywheel, clutch, 90-93 integra intermediate shaft and axles, 90-93 clutch cable(only if your stock one does not work). You will need to modify your stock linkage to work or you can buy one from a swap company like Hasport.
What model civic do you have??
You will also need a mount kit to drop the motor in your civic.
91 civic 4dr
b16a
14.8@94
Old 10-02-2002, 12:18 PM
will i need a new computer too or just the transmission and how will i know if my clutch cable will work
Old 10-02-2002, 12:19 PM
Yeah you will need a PR4 5spd ecu....and you will just have to test fit the clutch cable once the motor is in th car.
91 civic 4dr
b16a
14.8@94
Old 10-02-2002, 12:20 PM
also why will i need new axles and intermediate shafts if those are fine and also why do i need a new clutch and flywheel
Old 10-02-2002, 12:23 PM
You will need a clutch and flywheel because the auto doesn't have a clutch and flywheel, it uses a flexplate and torque converter. I am not sure if the axles are the same but I think the int shaft is. I would replace the axles anyway since they are pretty old. I see you have a std hatch. You are going to need to swap to dx/si hubs as well in order to use the b series axles
91 civic 4dr
b16a
14.8@94
97 GA wiring question/ Tranny question BlackZodiac Grand AM 4 11-03-2008 08:40 PM
1994 Diff Question and tranny question Marsal420 Sierra 3 07-25-2007 06:27 PM
Tranny questions and turbo questions... Marc-OS 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 1 05-08-2004 01:40 AM
b18a swap questions.. viridion '88 - '91 Civic | CRX | Wagon | Shuttlee 2 02-26-2004 05:53 AM
Tranny question. F20C Impreza/9-2x/Outback Sport 2 11-26-2001 07:36 PM
