Go Back   Automotive Forums Car Chat > Subaru > Impreza/9-2x/Outback Sport
Old 09-30-2002, 06:04 PM
PhatRex PhatRex is offline
Unhappy ECU Reset - CEL on after AVCR install
I have a 2003 WRX sedan, put in AVCR and it works great - but the CEL is staying on. Saw lots of threads on resetting ECU on older subs, but none for the newer cars. Any suggestions? I tried the battery diconnect and brake pedal thing - no go. Thanks.
Old 09-30-2002, 09:29 PM
Fireinthesky28's Avatar
Fireinthesky28 Fireinthesky28 is offline
Send a message via AIM to Fireinthesky28
I havent seeen this myself, but I am told there is a manual ecu reset under the wheel, off to the right near the center consule, a bit of a dig...
A yellow button I believe?
I doubt it will say 'Press me!', but it should be there.
If I am wrong, there should be a documentation in your manual
By the way....nice car, man
So the biblical scholars mis-translated the Hebrew word for "young woman" into the Greek word for "virgin," which was a pretty easy mistake to make, since there is only a subtle difference in the spelling. But back then it was the "virgin" that caught people's attention. It's not every day a virgin conceives and bears a son. So you keep that for a couple of hundred years, and the nexy thing you know, you have the Roman Catholic church.
-Snatch
Old 10-01-2002, 10:44 AM
FREED0MFiST FREED0MFiST is offline
Send a message via AIM to FREED0MFiST
You could just pull the fuse and let it drain for 20 minutes. What the heck is the brake pedal thing?
Old 10-01-2002, 11:35 AM
Yea...what is the break pedal thing??
-Snatch
Old 10-02-2002, 05:41 PM
The brake thing - a lot of the posts - at least 30 - say that once the battery is disconnected, you shpould step on the brake pedal to drain the last bit of power from the ECU. Yes - it sounds bogus, especially since the ECU has no seperate backup supply - I know 'cause I took it apart to verify the circuit board -
Yellow button - sounds too easy.
Was thinking of buying a scanner - but can't seem to find current year code books - are they the same OBD2 codes from the older asian books?
I have unplugged this darn ECU over and over, and still the CEL is on - I think I hhave narrowed it down to the Injen intake - sice the light stayed on even w/ the avc-r disonnected entirely.
Some folks sat the CEL may take a few hundred miles to reset - true?
Old 10-02-2002, 06:27 PM
Thats cool...
I saw this system advertised in C/D that was software for engine monitoring on a PDA, looked pretty badass -and- had the ability to clear triggers like those [silly] maintenance required lights, I dont know how appealing that is to you
-Snatch
Old 10-02-2002, 06:35 PM
I think scanners are pretty expensive....
Old 10-02-2002, 07:48 PM
Eh, I don't remember the price, if I ever see a link i will let you know...
-Snatch
Resetting ECU- 1995 Toyota Camry V6 XLE Techniker Camry/Camry Hybrid/Vista 1 07-07-2010 08:42 AM
Resetting CEL Light Jimbeaux Rodeo | Passport | MU 1 03-30-2007 05:41 PM
reseting cel jpzcd MPV 4 11-15-2005 12:08 PM
reset anything after intake install? 90CRXZCSi Focus | C Max 2 02-01-2004 04:18 AM
Reset ECU After CAI Install??? gotLUDE? Prelude 13 03-26-2003 09:39 PM
