Old 09-26-2002, 12:00 AM
zcrx1 zcrx1 is offline
Exclamation zc problem
i just swapped in a zc engine into my crx 6 days ago anyhow the problem is that when ever the car is on ilde it revs up and down by itself. it also effects my driving only at low rpms. it makes the car jerk forward and backwards when i drive from 1500 rpm to 3000 rpm. but when i go past 3000 rpm the car accelarates good. please help!!!
zc in crx dx
Old 09-26-2002, 01:46 AM
91civicDXdude's Avatar
vacuum leak probably. check all your vacuum lines for cracks, holes, or misplacing.
Old 09-26-2002, 02:49 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
what ecu you runnin. cause my friend was runnin a p30 on his sohc vtec and it surges too
Old 09-26-2002, 08:42 AM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
yeah...definitely check that you've got your vacuum lines correct...any codes?
SOLD!
Old 09-26-2002, 09:21 AM
Unhappy i checked the lines
i thought it was my vacum lines so i had some one with a crx dx with a zc in it to do my vacum lines. his car is fine but mine still has the problem. i am tried it with the pm7 and integra ecu and the problem was still there...could it be my distributor?
zc in crx dx
Old 09-26-2002, 02:00 PM
89CivicHBSi 89CivicHBSi is offline
Send a message via AIM to 89CivicHBSi
Its prolly your throttle angle sensor. Its on the side of the throttle body. Mine did the same thing just unplug it and see if it does it.. It will turn your Check light on but. it wont go up and down...
kurt
Old 09-26-2002, 02:14 PM
perndog1 perndog1 is offline
Send a message via AIM to perndog1
Yep I have the same problem with my ZC too, and having those urethane bushings in your motor mounts, you notice when the cars rpm's rise and fall because the car will rattle and then stop its kinda bothersome when your whole arm shakes. Thanks for that info as well i gotta check that out it might just be the engine mount bushings or the engine.
ian:smoker2:
Old 09-26-2002, 02:23 PM
Alright so i just tried what you said Kurt, god damn it worked like a charm. So that means my throttle angle sensor is bad or is that just how it is, if i can fix it I know where there is on sitting right know i can get cheap is that the solution to the rise and fall of the rpm's. thanks again kurt.
ian
Old 09-27-2002, 01:59 AM
Exclamation
can anybody show me the proper diagram for vacuum hoses for my crx dx with a zc egine installed??? please help
zc in crx dx
Old 09-27-2002, 10:15 AM
kris's Avatar
kris kris is offline
Off playing with fire.
DOnt know if this even helps:
Old 09-27-2002, 10:16 AM
kris's Avatar
http://www.thezcresource.com/html/zcbook.html
Problems Problems Problems... HondaChili MR2/MR-S 2 06-22-2004 03:12 PM
problems problems and more problems tacoma man Monte Carlo 1 05-12-2004 09:57 PM
ignition problem, transmission problem, you name it problem 1hotmama Sable 1 04-20-2004 12:17 PM
Problems, Problems and more.... Problems. Killa_CRX '88 - '91 Civic | CRX | Wagon | Shuttlee 6 03-02-2004 03:01 PM
Problems, Problems and More PROBLEMS!!!! 1PhatCX '88 - '91 Civic | CRX | Wagon | Shuttlee 15 06-21-2003 11:59 AM
