Go Back   Automotive Forums Car Chat > Mercury > Sable
Old 04-10-2004, 09:39 PM
1hotmama 1hotmama is offline
Unhappy ignition problem, transmission problem, you name it problem
1. When driving short distances i.e. 15 miles, switching off, and then attempting to restart, the car WILL NOT START. Not a battery problem because all electrical parts (lights, buzzers) work. The starter will not turn for a few seconds.
2. Does not like to shift down when stopping at red lights, etc. When accelerating from this position, the transmission slips out then shift hard into first.
ANY HELP???
Old 04-20-2004, 12:17 PM
mikeemon's Avatar
mikeemon mikeemon is offline
Re: ignition problem, transmission problem, you name it problem
1. Test voltage at battery and starter. Maybe make sure all connections are clean and intact. It could also be heat affecting your starter. These starters (as with most things on these cars) don't last forever and may need replacement.
2. Make sure fluid level is correct. See part 2 of above response.
Trans/clutch issue, what you think? PAINTER78 Engineering/ Technical 7 07-27-2010 07:53 AM
Clutch/tran Issues, what you think? PAINTER78 Eurovan/Multivan/Caravelle/Transporter 0 07-25-2010 02:56 PM
Alarmed by website highlighting Honda Odyssey Transmission Problems LibertyLoudSpeaker Odyssey 1 07-09-2010 03:03 PM
1994 Prizm possible transmission problem theginchico Nova | Prizm | Spectrum | Sprint 0 04-11-2010 12:52 PM
1995 3000GT Turbo manual transmission problem rene8603 3000GT/Stealth 8 10-08-2009 03:49 PM
