Old 09-25-2002, 09:44 PM
Santas90Si Santas90Si is offline
Registered User
Send a message via ICQ to Santas90Si Send a message via AIM to Santas90Si Send a message via Yahoo to Santas90Si
I have a problem...
My headlights are messed up. The left one will dim and brighten but the right one stays bright all the time. What is the problem? I was thinking a wire messed up or maybe the dim is out so the power just runs through the high beam at all times. Its the normal style headlights.
Old 09-25-2002, 09:50 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
When do you notice it? with the car on or off (or both)? At certain RPM's? When your stereo is on/off? Do you have a big stereo system (subs/amps, etc)? while your driving or while the car is at a stand-still?
Old 09-27-2002, 01:59 PM
Registered User
No its just when the car is at rest its like when the headlights are on the right one is on high beam and if you switch them it stays but the other one dims. I havent been able to drive it yet but I should be able to on saturday. I will tell you if it chages the way it happens when I'm driving.
Old 09-27-2002, 05:02 PM
ci5ic's Avatar
So, your passenger high-beam bulb is on all the time, but the low-beam bulb is not on at all?
just bought 2005 LSE V8... anyone have problems or tips? i got problems VanDarela LS | MKZ 1 10-19-2005 09:05 AM
Having problem with 92' Chevy Cavalier - Please Help feben Cavalier 2 05-10-2004 06:21 PM
Does any of you (p11) have problems with rear calipers? jprimera Engine 8 01-05-2002 01:28 PM
anyone have problems with purolator oil filters? u4ikstilz Engine 12 10-26-2001 07:34 AM
having problems with your chrysler??? olds88 Engineering/ Technical 3 08-26-2001 08:42 AM
