Old 09-25-2002, 12:22 PM
DMXer411713 DMXer411713 is offline
Send a message via AIM to DMXer411713
Unhappy Reverse Lights
I own a 91 Ford Escort LX and the reverse lights dont come on. How do I replace them? And what else could it be? All the other lights come on fine. Please help.
Old 09-26-2002, 06:13 PM
fordman123 fordman123 is offline
If both of the reverse lamps fail to illuminate, it is possible that the
MLP sensor or Range sensor has failed. It is mounted on the transmission and directs voltage to the reverse lamps when in the Reverse gear. If you need further assistance, reply to this thread and I will try to help you.
Good Luck
Fordman123
Technical Consultant
Old 09-26-2002, 07:58 PM
Smile continued
That sounds like it could be it, I cant say for sure if it is the bulbs because they are both out, it sounds like that could be it, can you tell me how to replace that part?
Old 10-02-2002, 07:49 PM
Find the component on the transmission where the shift cable attaches.
It should have,(but not limited to), 2 wires on it that control the reverse lamps. There should be a black wire with a yellow stripe and then a red wire with a dark green stripe. Once you find this component, just remove the screws/bolts and replace.
Good luck!
Fordman
Old 08-25-2008, 07:58 AM
1997 Taurus Wagon 1997 Taurus Wagon is offline
Re: Reverse Lights - 97 Taurus - also Center Brake Light
I have the same problem as the original poster (both reverse lights not working but all bulbs are good) AND my center roof mount reverse lights are the same (not working but both small bulbs are good). My car is a 1997 Taurus wagon and strangely I have noticed that when the rear hatchback is open causing the rear cargo/interior light to go on the center brake lights also illuminate but only very, very dimly.
Any thoughts out there?
Old 08-27-2008, 03:33 AM
Davescort97 Davescort97 is offline
Escort guy
Re: Reverse Lights
The hot wire to the mercury switch on the inside light is shorting out on the hot wire to the center brake lights. Frequently the wires run inside the rocker panels and moisture will get in there and cause what you describe. Go to the Taurus forum. The moderator there will help you out. He's very knowledgable.
rear-light warning signal and reverse lights up on brake 1993 Camry LE V6 patmanj20 Camry/Camry Hybrid/Vista 7 07-24-2008 01:01 AM
Reverse lights,alarm lights &signal indicator doesn't work Bigpauly52 7 Series 1 06-08-2005 02:34 AM
'90 Chevy 2500. No reverse lights. Where is Backup light switch? kpwall Engineering/ Technical 0 01-11-2005 07:46 PM
2000 Silverado--Reverse lights/cargo light Ruralmedic Silverado 6 12-30-2004 07:20 PM
no backup lights - reverse light switch? blhfla Golf 2 02-08-2004 01:51 PM
