Go Back   Automotive Forums Car Chat > Volkswagen > Golf
Old 02-05-2004, 12:59 PM
blhfla blhfla is offline
no backup lights - reverse light switch?
Where is the reverse gear light switch? The "backup lights" don't function but the fuse is OK. Does anyone have a suggestion besides the switch? 96 2.0 5 speed 4 door. Thanks.
- Bruce
Old 02-07-2004, 10:52 PM
termitesgraffix's Avatar
termitesgraffix termitesgraffix is offline
Send a message via AIM to termitesgraffix
check the relay. that is all those blach boxie looking things under the dash above the fuzes. they actually control where, how, and when what circuit does what... they can go bad too.
Old 02-08-2004, 01:51 PM
boschmann boschmann is offline
Re: no backup lights - reverse light switch?
There is no relay for the reverse lights on you vehicle. The reverse light switch should be on the top side of the transmission, near where the linkage goes in. It is a common failure. It has several wires as it has more than just the reverse light switch integrated into it (I think it has a 5th gear sensor too). To test, jumper the black/red wire (from fuse #14) to the black/grey wire which goes to the bulbs. If they light up (with the key on) then the switch has failed. If not look at the black/blue (yes, the wire changes color at a connector in the engine compartment) wires at the bulb holders to see if they have voltage when in reverse. The multi pin in-line connectors at the tail lights are also bad to get corroded. Also, be sure the bulbs are good.
Tail and Backup Lights NOT Working ezmak Problem Diagnosis 1 10-08-2010 09:24 AM
2000 Blazer Back Up Light Wont Turn On? panteli2011 Blazer 3 01-23-2010 07:23 PM
2001 S10 Tail Light/reverse lights skyler521 Problem Diagnosis 2 11-25-2008 08:19 AM
2001 Regal Backup/Reverse lights not working mikesmith20001 Regal 5 11-15-2007 06:53 PM
'90 Chevy 2500. No reverse lights. Where is Backup light switch? kpwall Engineering/ Technical 0 01-11-2005 07:46 PM
