Old 09-23-2002, 11:55 PM
mengy mengy is offline
Need some help with crank angle sensor
Ok to make a long story short. something went wrong with my car... my rpm goes crazy at high rpms... I checked ecu... it blinks 8 times... checked code list... it says "Check crank angle sensor and replace is necessary" Where is the crank angle sensor? and how would I go about checking it??? I have a 91 civic dx 4dr.
all I have in it is... custom intake.... I heard the dual point fuel injection doesn't respond well to mods... but I've had this for sometime now...
someone please help
thanks
Old 09-24-2002, 12:03 AM
dx_tuner's Avatar
dx_tuner dx_tuner is offline
I think code 4 and 8 are the same and a while ago I had a code 4 Crank angle sensor. And the only way to fix that I think is getting a new distributor. Thats how I fixed mine cause everytime the check engine light well come on my car would feel sluggish and I couldn't rev past 4000rpm. But it should be your distributor.
1989 Honda Civic HB DOHC VTEC 1.8L 07 2005
WWW.HONDA-TECH.COM
Old 09-24-2002, 12:04 AM
wow thanks so i have to get a new distro.... hmmm would a place like auto zone have it? or would I have to go to the dealer?
Old 09-24-2002, 12:05 AM
dx_tuner's Avatar
http://www.evotuners.com/civic_errorcodes.htm theres a site you can check the codes on
WWW.HONDA-TECH.COM
Old 09-24-2002, 01:56 AM
H4Bangin's Avatar
H4Bangin H4Bangin is offline
Send a message via AIM to H4Bangin
http://www.geocities.com/motorcity/s...5/ecucode.html
********** My 94 SS **********
90 civic dx 4 door d16z6 - p28, aem intake, act stage one clutch, cheap header- commuter car
Old 09-24-2002, 11:09 AM
cyberfelon's Avatar
cyberfelon cyberfelon is offline
Send a message via AIM to cyberfelon
Yeah dude i have '90 Si and had the same code, and I had to get a new New Distrubitor, i got one from Autozone, but it rebuilt one from Autozone, but it still showed the code. Apparently this is common problem. I found out fro a guy at the dealership that they dont rebuild the sensor properly in the ones from Autozone, so I had to get one from the dealership.
Old 09-24-2002, 11:33 AM
Thanks for the info.. I was just about to get one from autozone... whew..
Need some help with some performance stuff PBRoy Performance 1 02-09-2010 05:27 PM
Need SOME HELP Plz. Cranks Shaft Gear Broken!? mxzxracer16 Metro 3 01-18-2008 12:27 PM
Need some help with a 1996 eagle talon!!! PLEASE HELP talon_17 Off-Topic 1 10-02-2006 06:47 PM
I need some help with my springs Xxcivicex1169xX '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 8 12-09-2001 10:04 PM
