Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > General
General news, articles, other.
Old 09-01-2001, 08:01 PM
P11GT's Avatar
P11GT P11GT is offline
Send a message via AIM to P11GT Send a message via Yahoo to P11GT
Water Injection
We all know that inducing a fine spray of water into the inlet manifold can aid in performance i.e. causing the air to be denser for better combustion and cooler running, but how much water is too much.
The reason why i ask this is because, i was fooly around with somwe parts i had left over from my previous car and come up with an idea. Basically, ive created my own home made water injection kit, and wanted to know what you guys think, would it work or not?
The parts ive used are basic, a fuel pump and an injector. Basically, ive wired up an injector to the same power supply as the fuel pump, so when 12 volts is put into it, the pump runs and simultaniously opens the injector. The pump was then submerced in a becker of water. Ive enclosed some pics of the finished result.
Do you think that this could be modified to fit onto the intake system i.e. behind the air filter, to spray water into the inlet manifold, where it is then distributed along with the air.
UK's 1st Turbo'd Primera GT
Please visit my site www.p11-gt.co.uk Updated 7/3/2003
Some Exterior Mods to go now.
Vote for my car at www.ridejudge.com user name P11GT
VRRRROOOOOOMMM TIIISSSSSSHHHTT!!!
Old 09-01-2001, 08:02 PM
P11GT's Avatar
pic
Old 09-01-2001, 08:11 PM
P11GT's Avatar
pic
Old 09-01-2001, 08:12 PM
P11GT's Avatar
last pic
Old 09-01-2001, 08:17 PM
P10DET's Avatar
P10DET P10DET is offline
Re: Water Injection
A proper water injection set-up works well for a turbocharged engine because it significantly reduces the detonation threshold to the point that additional boost can be run.
It will decrease power in a NA engine because it will displace the fuel air mixture.
George Roffe
Houston, Texas USA
00 328i
91 SE-R (well modded)
84 944 SCCA ITS race car under construction
"I fear all we have done is to awaken a sleeping giant and filled him with a great resolve"
-- Admiral Yamamoto, December 7, 1941
Old 09-01-2001, 08:27 PM
P11GT's Avatar
there is a product on the market that is a very basic water bottle which attaches to the vacuum pipe and induces a fine spray of water into the inlet manifold. I cant find the site just now, but its supposed to be benifitial to the car, even non turbos, aiding fuel economy.
Old 09-01-2001, 08:35 PM
P11GT's Avatar
i was thinking of wiring up a micro switch to the throttle so that it would only work on full, something along the same lines as a NOZ kit. My main concern is like you say, water could collect, and too much could hydrolock the engine. The only other option, is to find a smaller injector or some sort of nozzle which produces a finer spray of water.
Old 09-01-2001, 08:52 PM
P11GT's Avatar
Im sure the site is www.invoauto.co.uk but cant seem to access it. The product is called the Vapour Jet.
Old 09-01-2001, 08:54 PM
P10DET's Avatar
I don't think you have to worry about hydrolocking your engine with such a spray system. Hell, I think your car would run like crap well before you would hydrolock it.
I wouldn't trust those telling you it would work with a NA engine. With a boosted engine, you don't have the same limiting factors as with a NA engine. The NA engine will only draw in so much air/fuel, and in this case, water. With the boosted engine, you can just keep adding air and fuel, so the water doesn't displace anything.
Make sense?
George Roffe
Houston, Texas USA
00 328i
Old 09-08-2001, 06:12 PM
G-Forces's Avatar
G-Forces G-Forces is offline
Banned
I would say if you think it would work install it and do some dyno'ing to test it. I know it will benefit a turbo car. But for an NA car..? You're being innovative at this point.
water injection kits Soyo 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 3 07-08-2003 04:30 PM
A3 Water Injection with Neuspeed SC ( Video ) f1racer General Discussion 0 06-16-2003 10:22 PM
At what stage would Water Injection be appropriate?? P11GT Engine 19 03-09-2002 12:56 PM
Alcohol/water injection Doctor Performance 8 01-14-2002 08:14 PM
With falling octane ratings is water injection the obvious solution? GoodJuan General 7 11-26-2001 01:17 PM
