ahhh e-brake light!
ok its been rainin a lot over here lately and when i go round corners my ebrake light comes on for bout 10 sec and then goes off. anyone had that prob?
Don't let my car fool you, b/c my treasure is in Heaven! My car is just a slice of it. |
sounds like some electrical bullshit, I wouldnt be too worried about it
AF Bay Area Crew ![]() 97 Toyota T100 xcab 3.4l v6 5spd 2wd |
fig'd that too. its just annoyin
You could try getting a new cluster, or checking all your wiring for water, or taking your console off round the ebrake and see if some connector there is fucked up.
or if your not that worried about it, you can always just take the light out.
Tony 91 Civic Sedan DX - Stock 287k Miles |
Try checking the wiring down at the bottom of your e brake lever. You will need to pull the center consol first however. Make sure no moisture has crept in there, and make sure the wire and plug are in good condition.
yo, mine did that just before my rear right wheel cylnder went out and almost killed me (locked my right rear tire up while going around 80) id prolly check them out or sumpin...hemll it might even be brake fluid.....
94 Integra LS, autotragic, Tons of mods 93 Accord wagon, Manual conversion and f20b swap in the near future! |
Re: ahhh e-brake light!
Check your brake fluid level, when the level gets too low there is a level float switch in the fluid reservior, and when you go around a corner as the fluid moves around in the reservior, the light will come on. The handbrake light is ALSO the low fluid level warning light as well. Just check and top up your fluid, it will be low. |
thanks guys ill check it out. i didnt know a 14 year old car had crap like that?!
Alright, I take back what I said. i would check that out, wasn't thinking about the brake fluid moving around in there around a turn. Definitely would check that out.
Damn, I feel like a dumbass now
Definately check the fluid level, i had the same problem in my VW. If it's not ur level it may be the switch. It's set up to warn u b4 u run out of fluid. By the way don't just fill it back up, if ur low it means u either need to do a brake job or u have a problem. Check it out & don't take a chance.
1993 Civic Coupe EX 1997 Chevy Suburban LT “It's all fun and games - Until someone loses an eye" |
