Old 09-15-2002, 07:47 PM
Marc-OS's Avatar
Marc-OS Marc-OS is offline
Send a message via ICQ to Marc-OS Send a message via AIM to Marc-OS
Installed aftermarket tach, RPM's seem way too high!?!
Alright, I just got a Proform 5" tach from Tolowhb, and I finished installing it earlier today. Now the tach in the cluster is still working, and I've noticed that the Proform tach is always around 400-500rpm higher than the stock tach. I know that the stock tach isn't the most accurate thing, but I'm fairly certain it shouldn't be that far off. What do you think could be causing the tach to be so far off?
10 PRINT "MARC-OS 0WNZ J00!!!"
20 GOTO 10
RUN
4/8/04 - My CRX is officially dead, RIP Lucy
Old 09-15-2002, 07:56 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
if you want to know if its off. take the car to rev limiter and if the tach matchs the cars rev limiter than you know the tach is accurate. also check to see when your car hits rev limiter that the tach reads that rpm, the same time you hit rev limiter
installing aftermarket tach in 2000 corolla scup27 Corolla/Matrix/Voltz 2 05-23-2008 04:24 PM
installing aftermarket tach 1984 V8 3100MPFI C/K 4 03-12-2008 09:02 PM
how to install aftermarket tach neonbob '88 - '91 Civic | CRX | Wagon | Shuttlee 5 10-16-2002 10:36 AM
