Old 03-11-2008, 09:02 PM
3100MPFI 3100MPFI is offline
Send a message via AIM to 3100MPFI Send a message via MSN to 3100MPFI
installing aftermarket tach 1984 V8
I want to install an aftermarket tach for my 1984 Chevy truck (5.0 V8). Where does the tach feed wire go? I am reading the instruction manual for the install, but it just says to check your trucks service manual (which I don't have).
Thanks.
Old 03-11-2008, 09:32 PM
escort_jay102 escort_jay102 is offline
Re: installing aftermarket tach 1984 V8
I could be wrong, but when I put a aftermarket tach on my older 454 there was a place by the distributor cap on the drivers side, that is black and says Tach on it, I did put it in there and it worked. I hope this helped...
1998 Chevy Cavalier
2.2/ K&N/ Ractive muffler
1994 Chevy s10
thrush welded muffler
Old 03-12-2008, 07:58 PM
kyle_1500 kyle_1500 is offline
if there is no tach lead, i beleive you can just put it on the negatice terminal of your ignition coil.
Old 03-12-2008, 08:36 PM
Working on it today, the ignition coil is integrated into the distributor itself.
I was looking at it, and there is no external coil, and if there is any writing on it to tell which is the tach wire, I can't make any of it out.
Old 03-12-2008, 09:02 PM
jasom jasom is offline
There is a wire that come from inside the rotor and plugs into the cap. I believe there is 2 open slots next to it. Find a female conector that will match up to male end if your wire coming from your tach doesnt already have one and just plug into one of them.
