Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Maintenance
Maintenance problems, fixes.
Old 08-29-2001, 08:51 PM
Jagmeister Jagmeister is offline
OBD Scan Tool and Oxygen Sensor Location
I would like to recommend a OBDII Scan tool I recently purchased.
I have been able to use it twice now to figure out why that pesky Check Engine light keeps coming on. And, turn the silly thing off. I'm getting a P0136 code which seems to be Oxygen Sensor #2. My Chiltons Manual does not tell me where this little bugger is located at. Is it the one screwed into the exhaust system?
I looked and looked for a reasonably priced scan tool but they are all pretty expensive. And if I figured if I was going to shell out the bucks for one it had better do all my vehicles and not just the G20.
I finally stumbled across the solution. You do, however, need a computer (or Palm Pilot) to use it. It comes as two pieces; the software, and an interface box with one end that plugs into the car and the other end plugs into the computers serial port.
It has a lot of nice features besides reading and clearing the trouble codes. You can read and log live data as you are running the engine (or driving if you have a laptop).
For $110 you can be all setup for imports. I opted for the $140 package which covers ALL vehicles. I figure it will pay for itself the first or second time I use it to solve my own problem. Check it out yourself.
http://www.ghg.net/dharrison/obdscan.html
I am not affiliated with the company in anyway. Just a satisfied customer.
Matt Grimes
95 Infinity G20t - The Daily Driver
86 Jaguar XJ6 w/350cu V8 - For Nice Days
Old 08-30-2001, 03:05 AM
A380Driver A380Driver is offline
Send a message via AIM to A380Driver
93.5 P10 is OBDI or OBDII? Im guessin ur 95 was OBDII ...tho the site says 96' or later cars?
-Brian Jones
I got a snake man
Old 08-30-2001, 08:26 AM
Following info was provided by FlossinPrimera to an earlier post of mine:
OBD I is for G20s up through the 1993.5 model year, the 94+ G20s are OBD II
Matt Grimes
Oxygen Sensor sasheehan Almera | Sunny | Pulsar | Bluebird | Tiida | Versa | NX | Avenir | Tino | Stanza 6 04-01-2012 08:19 PM
obd2 plug scan tool will not connect sdime9484 Problem Diagnosis 1 01-01-2010 11:49 AM
Bank 2 Sensor 1 Oxygen Sensor location and removal sleepwalker Aurora 3 10-25-2006 03:27 PM
TSB & OBD Scan tool MXC_Rider C/K 1 03-24-2004 09:26 AM
