Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 09-11-2002, 11:25 PM
gwako gwako is offline
bump stops
I was just wondering what is the reason for cutting bump stops on shocks when installing lowering springs ?
Old 09-13-2002, 05:18 PM
Duatone Duatone is offline
Have you ever ridden in a car that is riding primarilly on bumpstops? It gets REALLY bouncy, so when you lower lower your car, it shortens your strut length which will tend you to be on a closer rate of bottoming out (depending on what kind of setup you have though), so you want a little bit of your bump stock left to prevent your strut from completely bottoming out, but not riding on your spoungy rubber more than the spring... If someone else can clarify for you what I mean, then by all means do it, but i bekeive this is the basic principle of it all.
so far:
1990 accord ex
JDM F22B DOHC/Nakayama cold air intake/Nakayama exhaust/18" Enkei Zoku painted black/Yokohama Parada Spec II/Full air ride/shaved doors & mouldings/VIS R34 front bumper blah blah blah...
Old 09-13-2002, 06:11 PM
I really don't understand....what is the reason for cutting it, why don't they just leave it the way it is....
Old 09-14-2002, 02:16 PM
delsolsi delsolsi is offline
Lets say you lower you car 2" with lowering springs, but you use the same size strut, stock or hopefully aftermarket. You will lose 2" of strut travel because the car is now sitting 2" lower, which compresses the strut 2". By cutting the bump stop you regain some of this lost strut travel because the strut can now compress more before it hits the bump stomp. You don't want to complety remove the bump stop or your strut will bottom out on full compression and ruin the strut. There are some coil-over kits available with shorter struts so you can have both a lower ride hight and plenty of suspension travel.
Bump Stop question ( H&R spring) Darren6210 Tires and Wheels 2 03-14-2004 08:28 AM
92 Accord EX dropped 2 inches and is either hitting bump stop or bottoming out! no2morrow Accord/TSX/Accord Hybrid 13 02-26-2003 08:15 PM
Bump Stop / Ride height question Alexxn 00 Si Tires and Wheels 6 10-29-2002 02:03 PM
Bump Stops mmasse Tires and Wheels 6 05-12-2002 09:51 AM
Aftermarket Bump Stops Mike H Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 10 07-25-2001 12:31 PM
