Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 10-29-2002, 07:10 AM
Alexxn 00 Si Alexxn 00 Si is offline
Arrow Bump Stop / Ride height question
OK everyone, here is a good one....on my 00 Civic Si I had H&R Sport springs which in the front were supposed to lower 1.75 inches. I have 17 in wheels with 205/40/17 tires. There is absolutely no fender gap - in fact the tire even sits a little under the fender. On the passenger side when I take a right hand turn quick and hit even a small bump the tire rubs on the inner fender liner. When I spoke to H & R about this they told me that the person who installed these (I bought the car that way) probably cut the bump stops. Would that matter ? Do the bump stops actually support the weight of the car ? I thought that they only came into play to keep the shock from bottoming out. I don't know anyone with a stock Civic Si so I can measure the distance from the center of the wheel to the top of the fender opening so I can compare it to mine and see how much lower it is.
Can anyone help ?
2005 Chevrolet Silverado 2500HD Ext cab
Old 10-29-2002, 08:07 AM
Also I am thinking about switching to an Eibach Pro Kit. Are these more realistic in terms of ride height for a daily driver and or in the snow ?
Old 10-29-2002, 08:53 AM
CivicSiRacer's Avatar
CivicSiRacer CivicSiRacer is offline
Civic Mod
Send a message via ICQ to CivicSiRacer Send a message via AIM to CivicSiRacer
Well actually it doesn't sound like H&R do not know whatthey are talking about. Scary.
Anyway what is the size & offset of your wheels. Offset will make a big difference on if you rub or not. The best setup would be 17x7" with 42-44mm offset. 40mm offset may or may not rub.
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes
Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!
Autocross Help Page
Buy my Civic parts!
Old 10-29-2002, 09:07 AM
The rims are Tenzo Poke 10's, size 17 x 7 and offset of 42.
What do you think about Eibach Pro srings ? Raise the car some and keep an softer ride ? I also have some Ground Controls front rate is 340 and rear is 250. I'd like to keep a softer ride for the street.
Your thoughts ??
Old 10-29-2002, 01:21 PM
Civic Mod
Your thoughts ??
I'm running 350f/400r GC springs and it's barely stiff. I would just raise the car up 1/4-1/2".
Autocross Help Page
Buy my Civic parts!
Old 10-29-2002, 01:39 PM
You mean raise it 1/4 to 1/2 from where it is now by using the Ground Controls ?
Old 10-29-2002, 02:03 PM
Civic Mod
Your thoughts ??
Autocross Help Page
Buy my Civic parts!
