Old 09-11-2002, 07:24 PM
dfarres's Avatar
dfarres dfarres is offline
Send a message via Yahoo to dfarres
Blinker ??????
I replaced all my bulbs when i bought my car & my blinkers in my bumpers work but the ones in the corners don't. What's my problem???
Every light on my car works except those.... is there a relay or something i don't know about?
1993 Civic Coupe EX
1997 Chevy Suburban LT
的t's all fun and games - Until someone loses an eye"
Old 09-11-2002, 07:34 PM
DarkImportGrey's Avatar
DarkImportGrey DarkImportGrey is offline
Send a message via AIM to DarkImportGrey Send a message via MSN to DarkImportGrey Send a message via Yahoo to DarkImportGrey
did you replace the corner bulbs? the really tiny ones?
Old 09-11-2002, 09:39 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
There should be 2 bulbs in the corner lenses. The front one (under the clear part of the lens) is a parking light, should come on with the head-lights. The one under the amber part of the lens is kindof a side-marker turn-signal, and comes on with the head-lights, but blinks as a turn-signal... I don't know if that helps at all... I don't know exactly how they're wired, but if neither side works, it's probably the flasher relay.
Old 09-12-2002, 02:53 AM
H4Bangin's Avatar
H4Bangin H4Bangin is offline
Send a message via AIM to H4Bangin
does it blink fast?? or just make a wierd noise?
********** My 94 SS **********
90 civic dx 4 door d16z6 - p28, aem intake, act stage one clutch, cheap header- commuter car
Old 09-12-2002, 10:38 AM
dfarres's Avatar
Like i said, i have replaced all the bulbs. I know how it's supposed to work, the corners and bumpers flash together with the headlights off and alternate with them on. My blinkers work fine otherwise (not fast & no noises) & my running lights work fine also. I'm just confused to why the corner blinkers don't work when everything else is fine.
1993 Civic Coupe EX
Old 09-12-2002, 11:08 AM
EF_LSVtec's Avatar
EF_LSVtec EF_LSVtec is offline
Send a message via AIM to EF_LSVtec
Did you replace em with double contact bulbs?
AF Bay Area Crew
Fully Built LSVtec Motor (245.8 whp/164.6 torque)
88 DX Hatch to JDM SiR conversion
Retired SOLD 1/08
Licensed Mortgage Consultant (Calif.)
Cellular 415.699.1797
Old 09-12-2002, 11:12 AM
dfarres's Avatar
I replaced them with the bulbs that r listed in the manual only orange in color since i have clear corners.
1993 Civic Coupe EX
Old 09-12-2002, 12:30 PM
EF_LSVtec's Avatar
Not really sure what your problem is...you replaced your bulbs but the corners dont work?...they dont blink? do they even light up? if they do, do they light up w/ the headlights or not? or totally not at all?:flash:
AF Bay Area Crew
Retired SOLD 1/08
Old 09-12-2002, 12:43 PM
dfarres's Avatar
The front bulbs (running lights) in the corners work fine but the side bulbs (blinker) don't come on at all. I'm stumped....
1993 Civic Coupe EX
Old 09-12-2002, 12:51 PM
EF_LSVtec's Avatar
thats weird because if you're bulb's out, then other blinkers will hyperblink...try putting back the old bulb and check...if they work again, get a double fillament blinkers in yellow to replace em.:flash:
AF Bay Area Crew
Retired SOLD 1/08
Old 09-12-2002, 01:06 PM
H4Bangin's Avatar
Get a meter and check if ur gettin any power to it
Old 09-12-2002, 01:08 PM
dfarres's Avatar
it never had the bulbs in it when i bought it so i don't know the last time they worked. i'll try different bulbs but i don't think that's the problem.
1993 Civic Coupe EX
Old 09-12-2002, 01:12 PM
EF_LSVtec's Avatar
I wonder if you reversed the plugs by accident...just a thought...
AF Bay Area Crew
Retired SOLD 1/08
Old 09-12-2002, 01:16 PM
dfarres's Avatar
i can't, they have different sockets, besides my running lights work fine & they're in the front socket.
1993 Civic Coupe EX
2007 mustang blinker a1c little Mustang Problem Diagnosis 2 01-13-2010 07:10 AM
blinkers quit 97 eagle talon chucky123 Eclipse Problem Diagnosis 0 11-24-2009 10:45 PM
Blinker relay noise when blinkers not on laxman21 Problem Diagnosis 6 07-07-2009 11:06 AM
Blinker sound, no blinker on Frankiscav Cavalier Problem Diagnosis 1 12-10-2006 02:59 PM
car making the blinker sound when the blinker is not on! JessicaJane Suburban 5 11-10-2004 09:27 AM
