Old 09-11-2002, 12:59 AM
magicmanjk808 magicmanjk808 is offline
Send a message via AIM to magicmanjk808
need help with putty, i've searched but found no answers
wassup, im not sure if this has been answered, but i couldn't find it in the searches i did. anyway, im working with tamiya 2 part epoxy putty, smooth type and was doing some body work. after sanding and primering, i thought i was ready for the final coat. after i sprayed the final coat, i noticed, you could see where the putty was because the paint shinier there. is it because im using the smooth type? any help will be appreciated. thanks.
Current Project:
Fujimi Toyota Altezza RS200
bye bye handles, moldings, rain gutters, license plate holders
View some pics of it here http://www.automotiveforums.com/vbulletin/t72123.html
Old 09-11-2002, 03:14 AM
Did yah throw some primer on first?
*edit* opps.. I re-read it and you did say primer, srry not sure what to do.
AF MODELING FAQ
"Oh what a feeling.- Toyota
Old 09-11-2002, 08:08 AM
935k3's Avatar
935k3 935k3 is offline
If you can find it get some Duplicolor Primer sealer and spray that over the primer. Also if you go to an Automotive supplier that deals in paints etc. for real cars get DYNATRON PUTTYCOTE glazing spot putty. It is a two part mix. It is designed to seal other fillers and putties, it is the finest grain putty available, it can even be polished to a shine, it's great stuff. Dynatron is owned by BONDO and Bondo sells something called Bondo Ultimate at WAL-MART and K-MART that might be the same because it uses a blue hardening cream also and it costs allot more than regular BONDO. Give it a try you won't be sorry.
Old 09-11-2002, 08:18 PM
hirofkd's Avatar
hirofkd hirofkd is offline
Sounds like primer wasn't thick enough. Thinner primer is desirable, so that it won't make the details dull, but after doing some major body work, this rule may not apply. What you can do is to spray a few coats of primer, then sand the entire body with fine grit sand paper, such as 2000 grit. Clean the body, and add another few light coats of primer. The 2nd coat of primer should fill the scratches on the first primer, and that will probably make the surface uniform. If not, try polishing the primer, before adding another layer.
This also applies to polyester putty and typical modeling putty.
Hiroaki Fukuda
Old 09-11-2002, 09:21 PM
thanks a lot, i'll give it a try and let you all know how it turned out when i show you pics of my altezza. dont know when im going to finish it though, waiting for a shipment from hlj, and hobbysearch. thanks again.
Current Project:
need help with parts search! mex.revolutionist Maintenance 0 08-26-2006 11:03 PM
I've messed up, need help with a botched silver paintjob mickbench Car Modeling 12 07-10-2006 04:13 PM
Overheating Problem...I searched but no answers Jung2 Camry/Camry Hybrid/Vista 3 01-08-2006 05:17 AM
I'm a honda guy but i need help with a RX7 HondaSi88 RX-7 24 02-08-2004 12:30 AM
I really need help with this! It seems not modelling related but it is. bah humbug Car Modeling 8 07-08-2003 08:02 AM
