Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > General
General news, articles, other.
Old 08-29-2001, 12:57 AM
slickkedar's Avatar
slickkedar slickkedar is offline
Rotors- slotted or cross drilled??
Which is better and why?? Also, im thinking of getting some aftermarket ones- which company is the best??
Old 08-29-2001, 03:12 AM
G22DET's Avatar
G22DET G22DET is offline
Send a message via ICQ to G22DET Send a message via AIM to G22DET
Brembo is the best, slotted and cross drilled all serve the same purpose..allow heat to escape from the brakes faster.
Luke C.
GDA Power!
Old 08-29-2001, 03:39 AM
Anthony Anthony is offline
I'd personally go for slotted rather than cross-drilled, as cross-drilled rotors have been known to crack.... and that isn't cool
Owner of Primeraweb, and a 1997 Nissan Primera SRi driver
Old 08-29-2001, 03:41 AM
G22DET's Avatar
not if you get the brembos...i have them for about a year now...went to various tracks and they work great.
Luke C.
GDA Power!
Old 08-29-2001, 06:37 AM
G20-KIWI G20-KIWI is offline
Cross drilled rotors are sweet as, but if you cross drill existing
disc rotors then they crack.
Brembos kick ass! The Godzilla Skylines use them and they stop
faster than many of the supercars today.
-=G20-KIWI=-
Old 08-29-2001, 07:00 AM
P10DET's Avatar
P10DET P10DET is offline
Re: Rotors- slotted or cross drilled??
Get them for looks if you like. If you are getting them because you are hoping for better performance, you won't get any. So, if you want to get them for performance, spend the money elsewhere. A better set of pads, or better yet, SS lines would be a better investment.
George Roffe
Houston, Texas USA
00 328i
91 SE-R (well modded)
84 944 SCCA ITS race car under construction
"I fear all we have done is to awaken a sleeping giant and filled him with a great resolve"
-- Admiral Yamamoto, December 7, 1941
Old 08-29-2001, 08:37 AM
Lee Lee is offline
Re: Re: Rotors- slotted or cross drilled??
i totally agree with George. :smoker2: For street use, better to go with non slotted/cross drilled. for the track, it MAY help with brake fade a tad more, but good pads will do that as well. I mostly see people doing this for form over function. Brakes are the area where function over form should be the general rule.
as for pads, EBC Greens for street, Reds for track. Hawk and AXXIS (metal masters) also make damn fine pads. As for SS lines, I got my set from STeve @ SMC over a year ago and have been completely satisfied! A great investment for any kit! (pretty and match my blue calipers... Also, a good brake system flush and some good brake fluid wouldn't hurt either! alot of guys rave about motul, but i have only used castrol dot 5 abs myself. (since i have ABS)
On a side note, SMC has a BABK for the P10 using redrilled hats from a 300zx Turbo. You will have to supply the calipers though. May want to check that out too!
Old 08-29-2001, 12:21 PM
kris's Avatar
kris kris is offline
Off playing with fire.
This is true if you drill solid rotors. Brembo casts there rotors with slots, so thats why they dont crack (i think)
I needed to replace my rotors not to long ago. Rather than go with solids from the local parts store. I flipped an extra $40 and got the Brembo Cross Drilled/Slotted rotors. They look great, but as for better stopping power, I dont think I notice any difference. I guess you would need to upgrade to a bigger brake kit to get better stopping power.
Old 08-29-2001, 01:53 PM
A380Driver A380Driver is offline
Send a message via AIM to A380Driver
Would cross drilled rotors help in stopping any warping of the disc? ...lets say if we were braking on the street rather hard...
Check out these upgrades for the G20/ SE-R
http://www.hpracing.com/
11 1/2 inch cross drilled and slotted rotors...
SS brake lines
If you get the stage 2 kit it comes with new calipers
I think its like 2k or somethin tho...quite alot
-Brian Jones
I got a snake man
Old 08-31-2001, 10:44 PM
FlossinPrimera FlossinPrimera is offline
Send a message via ICQ to FlossinPrimera Send a message via AIM to FlossinPrimera Send a message via Yahoo to FlossinPrimera
Slotted is the safe way to go. Drilling and slotting does not acheive the same end. Drilling is to help the disc cool faster. Slotting is there because the act of braking makes the pad release a gas that impeads braking, the slots release this gas. As for getting more braking power. Larger rotors are not necessarily needed. A high quality rotor and super grippy pads (Metal masters) will yield a great increase in braking preformance. But you only have so much grip, so get some wider wheels and tires, voila you have just shortend your braking distance. Not that the G20 had a long braking distance to begin with. P10 G20 with ABS did 60-0 in 125 feet, thats super short folks, Mustang Cobra territory (BTW the Cobra is regarded for having excellent brakes).
1994 Infiniti G20 5 speed (rebadged as Nissan Primera)
K&N, Enkei Type 11 GML, JVC KD-SH55 Digifine, Pioneer Pear-mica components, 2 12" round things that bang and a 400W amp to make them bang. Coming soon: ACT clutch, new half-shafts, HKS superform springs, KYB AGX adjustable shocks, $tillen STB, 17" König Toxxins with Yokohama Parada Tires (P215/40R17).
http://gforces.streetracing.org/
"I wish Captian Archer was as much as a racial bigot as Captain Kirk"
-Burt Weed
slotted ,cross drilled or both please answer quick!! torch2004 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 3 08-13-2002 09:29 PM
rotors, slotted, cross-drilled, plain??? 94tegRS Integra 8 02-15-2002 01:15 AM
Cross Drilled or Slotted Rotors? 90CRXZCSi '71-'87 Civic | CRX 9 01-29-2002 10:02 PM
Crossed drilled/slotted rotors. kris Engineering/ Technical 14 01-26-2002 03:31 PM
