Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 01-27-2002, 06:18 PM
90CRXZCSi's Avatar
90CRXZCSi 90CRXZCSi is offline
Send a message via AIM to 90CRXZCSi Send a message via Yahoo to 90CRXZCSi
Question Cross Drilled or Slotted Rotors?
Which would you guys prefer? I was looking to upgrade my brake system to cross drilled or slotted but i wasnt sure which ones to get. Anyone have any suggestions?
2004 Sonic Blue Ford Ranger XLT
2001 Liquid Grey Metallic Ford Focus ZX3
1995 Integra GS-R - Parting out
Old 01-27-2002, 08:01 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Neither, have you ever noticed that for several years now F1 has been using vented discs only. no holes and no slots. The Australian V8 touring cars are also doing the same thing.
On a street car you also dont realyl gain anything other than the look and much faster pad wear.
If your interested in makeing the car stop faster then invest in some rear discs from an Si or an Integra, and then look at swapping Accord frount discs on. Or if your feeling wealthy then find a Big brake kit.
But retianing the same disc and caliper size but adding holes or slots will do nothing extra for your braking.
Old 01-27-2002, 08:05 PM
spy54's Avatar
spy54 spy54 is offline
Send a message via AIM to spy54
really? then why do they make them?
AF Teen Crew
Purehonda.com - may she rest in peace
1996 Chevy C1500, Flowmaster Exhaust, Tinted Windows, 2 Kicker 10" L7 Subs, Eclipse 5v headunit, Alpine V12 Amp
DJM 4/6 drop kit being sold
Full Throttle 9.5 inch lift being installed
1989 CRX si "silver mist"---SOLD---.....Stripped and Wrecked in Compton
corbeau forza 2 seats, DC short shifter, Powerslot slotter rotors, AEM brake pads, Bfgoodridge Stainless steel brake lines, Greddy MX exhaust, AEM Cold Air Intake, Konig Rated-R rims, Kamikazi header
Make an Offer [email protected]
Old 01-27-2002, 08:14 PM
RaceInspired RaceInspired is offline
Send a message via AIM to RaceInspired
Err... somethin about back in the day, the pads would give off these fumes or gases, and the drilled/slots would help vent that. Now, the pads dont do that, so, why use crossdrilled (less braking surface = less braking power!)?
I say, go w/ Powerslot, i like mine!
Representin' my crew in NoVA...
Old 01-27-2002, 08:22 PM
90CRXZCSi's Avatar
hmmmm
Well i have a Si which came stock with 4 wheel disc and then i upgraded to integra rotors. They work fine but i need a good stop for over 100MPH.....J/k I just dont feel like they work all that well and when im gonna be gettin alot more mods, im sure i'll need something more to help me stop.
Old 01-27-2002, 08:26 PM
Moppie's Avatar
Master Connector
Yeah, thats pretty much the theory behind it.
Drilling and sloting a disc also weakens it and leave its more vunrable to cracking.
The reason they still sell is simple, it because people still buy them.
Infact there is still a lot of debate over how effective they are, and I know a lot of modern race cars still use one or both, as the enginers beleive with good evidence that they work.
However F1 has always been a leader in technology, and the Aussie V8s despite thier simplicity are also right up there, so I feel more inclined to follow thier practices.
But more stopping power means more force must be applied to the wheel, which means more surface area for the pad to grip onto, i.e. larger multi piston calipers, and more leverage for the pad to work with, i.e. larger diameter discs.
Retianing the same size disc but slotting or drilling it, may reduce brake temps a little, but only if gas build up is a problem, (and theres a high chance it isnt) but they also reduce the amount of surface area the pad has to work over, and also the amount of metal exposed to the air and so able to disapate heat.
Old 01-28-2002, 10:06 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
yes its true, the drilled/slotted rotors show no actual gains in stopping distance, but over several panic stops done in testing, there was less brake fade, but unless you drive 100mph stoplight to stoplight brakefade wont be a big issue, but they look cool.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 01-28-2002, 11:03 PM
91HBSi 91HBSi is offline
Send a message via ICQ to 91HBSi Send a message via AIM to 91HBSi Send a message via Yahoo to 91HBSi
Well I got some Brembo X-drilled and slotted rotors for the same price as OE replacements I decided to just get the cooler looking ones, but yeah I agree with you guys. It is like tires, the bigger the contact patch the more grip. Tires with lots of grooves and crazy designs are just for looks, unless you are concerned about hydroplaning (which I am sure no one takes safety into acount :licker: )
Lexus SC300 (Kazera KZa 18"x8.5" 245/40 (front), 18"x9.5" 275/35 (rear)... put on hold.
Civic Hatchback Si (I/H/E, d16z6 head, H&R springs/tokico blues, etc.)
94 Prelude Si (Sold!)
Former PureHonda.com member since Dec. 00
"For to me, to live is Christ and to die is gain." Pilippians ONe21
Old 01-29-2002, 05:09 PM
PFCfutrell PFCfutrell is offline
Send a message via AIM to PFCfutrell Send a message via Yahoo to PFCfutrell
Cross-drilled rotors weigh slightly less than regular or slotted rotors and offer a little less un-sprung weight in a race car. Unless you've stripped your car completely and are going for absolute minimum weight stick with regular or slotted rotors.
1991 CRX SI (black)
15.3 @ 88mph (stock motor)
'90 B18A1 swap
Custom exhaust
*2.25" piping
*two glasspacks (inline)
*polished flash-cut tip
*exits pass. side, front of rear tire.
'95 GSR 15" wheels
195/50/R15 Bridgestone Potenza SO-3's
AE Eng. front crossmember
Susp. Tech. 22mm rear sway bar
Susp. Tech. 1.8" lowering springs
Tokico Illumina 5-way adj. shocks
Powerslot rotors
Metal Master pads
Goodridge steel-braided brake lines
Red painted OEM calipers
Skunk2 short shifter
Skunk2 shift knob
GT Grant steering wheel
Red/black racing seats
Old 01-29-2002, 10:02 PM
Well, I already ordered mine... there's no turning back. I just like the "look." I am sure they will work well too, so it's cool. :licker:
