Go Back   Automotive Forums Car Chat > Honda > Integra
Old 02-10-2002, 01:55 AM
94tegRS's Avatar
94tegRS 94tegRS is offline
rotors, slotted, cross-drilled, plain???
OK, I can get brembo rotors for front and rear right and left on my car that arre cross drilled and slotted for 190 bucks
http://cgi.ebay.com/ebaymotors/aw-cg...949423&r=0&t=0
I have heard that the cross druilled can crack, is this very common though? and is it aftre alot of wear or is it just that they are weak and can break like right away?
Old 02-10-2002, 12:11 PM
ImportNut1212 ImportNut1212 is offline
Send a message via AIM to ImportNut1212
its more common to see cracking in cheap brake kits...brembo is the top of the line for the most part, and i wouldnt expect them to crack right away, or at all in the future.
original tofu crew member #06
my car=95 240sx se w/ s14 sr20det
lUcAs-----
Old 02-10-2002, 12:21 PM
94tegRS's Avatar
ok, I hope not, is there a definite difference in braknig between the stock and the brembo slotted/cross-drilled rotors? will I be able to notice it.
Old 02-10-2002, 12:25 PM
the cross drilling, and slotting aren't really for brake power, they more or less prevent brake fade by keeping everything cooler. the diamter of the brake disc is what matters, what size are they? if you want to, IM me on AIM at "mustang43084" to talk about it....this is slow.lol
lUcAs-----
Old 02-10-2002, 12:31 PM
94tegRS's Avatar
well, i dotn got AIM, got YIM and MSN,
both are maddmatt02
and I dont really use my brakes much to rreally worrry about that kind of heat now, but with my new car i will probably be slowing down from in the hundreds more, so i might have to worry now. how long does it take under extreme brakeing for the stock rotors ton get too hot to work properly. will stopping from about 130+ be a long enough stop to require better rotors?
Old 02-12-2002, 07:53 PM
blk94ls blk94ls is offline
Send a message via AIM to blk94ls
u can get those same brakes on www.import-trader.com for 120 bucks a pair...
Old 02-13-2002, 01:55 AM
94tegRS's Avatar
so there is 240 bucks for al 4 corners, I will stay with the 190 for all 4 I found, I see how i might have lost ya tho
Thanks anyways.
Old 02-14-2002, 05:26 PM
higgimonster's Avatar
higgimonster higgimonster is offline
both are maddmatt02
You should really try to stop more often
As far as drilled and slotted rotors are concerned...
as someone stated earlier, they help with cooling but the other benifits are they weigh less (less unsprung weight then standard rotors), less rotating mass (which makes the wheels have more mass in a sense, feels like more mass at least), and they are less likely to warp due to the structural rigidity from the hollowed centers.
Old 02-15-2002, 01:15 AM
94tegRS's Avatar
ok,well, I am pretty sure I am gonna get them towards the end of the month if the guy can get another shipment or whatever, he sold 6 of the 7 sets on auction last time. but I am also waiting to do this, because when i do it I am removing my calipers completely, and painting them, getting some new pads also. and I need my car to often these days to be without the calipers for a while and no time to bleed them when i get em on so it has to wait
slotted ,cross drilled or both please answer quick!! torch2004 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 3 08-13-2002 09:29 PM
Cross Drilled or Slotted Rotors? 90CRXZCSi '71-'87 Civic | CRX 9 01-29-2002 10:02 PM
Crossed drilled/slotted rotors. kris Engineering/ Technical 14 01-26-2002 03:31 PM
Rotors- slotted or cross drilled?? slickkedar General 9 08-31-2001 10:44 PM
