Old 10-31-2006, 06:38 PM
speeddemon92's Avatar
speeddemon92 speeddemon92 is offline
white or gray?
hi everybody,i'm about to pant my oldsmoble nascars in tamiya camel yellow. this is scary because i have never primed a kit body before. i was wondering what primer to use. i was thinking white, but i'm not sure. i thought that grey would come through under the camel yellow, but i've never done this before. i don't know whitch primers to use under what colors.
thanks for the help
Old 10-31-2006, 07:13 PM
tigeraid's Avatar
tigeraid tigeraid is offline
Authorized Vendor
Re: white or gray?
thanks for the help
Both. Lay a couple of decent coats of grey primer--use it to find problems in the body, things that still need to be puttied or sanded etc... once you're done all that stuff, lay one more light coat of gray, and then a couple of good coats of white primer. Yellow most definitely will not cover grey primer easily. A good rule of thumb that lots of guys here follow is to use white primer as your final primer coat on anything except the odd black or dark blue colour ,that sort of thing.
Old 10-31-2006, 07:53 PM
freakray freakray is offline
AF Modelrater
Re: white or gray?
Some useful info:
http://www.automotiveforums.com/vbul...=primer+yellow
AF User Guidelines
Old 11-01-2006, 03:42 PM
924_CarreraGTS's Avatar
924_CarreraGTS 924_CarreraGTS is offline
Re: white or gray?
So where can you get white primer? I use PlastiKote, which is rust-colored. I have never found white primer anywhere.
Old 11-01-2006, 04:39 PM
tigeraid's Avatar
Authorized Vendor
Re: white or gray?
Tamiya sells it, as does Dupli-color. I don't recall if Testors does.
Old 11-01-2006, 07:10 PM
rsxse240 rsxse240 is offline
Re: white or gray?
for nascar, and other really brightly colored cars, I like to use bright colors like silver, and gold of various tints (graphite, gunmetal, silver, bronze, copper, aluminum etc.) it really tends to make the color pop. it may not be correct for your application, I just thought I'd share.
Old 11-02-2006, 02:36 AM
cyberkid's Avatar
cyberkid cyberkid is offline
Re: white or gray?
Gunze also has a 1000 grit sandable white primer in a bottle. Tamiya's stuff is too air-y for me...even when decanted...
Please read the following linked articals before posting a question.
Once you have and still have questions, try to post your questions clearly.
This will make a lot of people's blood pressure drop back to normal, including mine.
NEW TO THE AF MODELLING FORUM? PLEASE READ THIS FIRST
AF Car Modeling Tutorial, How-To and Product Review Depository
AF Car Modeling Frequently Asked Questions [FAQ] - * Look here first! * ver2.0
And finally,I wish you all happy modeling
Old 11-02-2006, 05:50 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
Re: white or gray?
You could make up a couple of test pieces from scrap plastic or cardboard and try out the white and gray to see how the yellow looks over each.
I'll also use the gray primer to do my body work with a cheaper Plastikote primer and then use Duplicolor for the finish work right before the final painting.
Bob
