Old 09-06-2002, 07:08 PM
accord92 accord92 is offline
rear camber
i have a 92 accord. i already have a kit on my front...but my rear tires are cupping a little, so i need to get a camber kit put on the rear. i have heard about fixing your rear camber with just some washers...does anyone know anything about this. if so please help me out with some info...if this is just some bs than what is a good camber kit to go with.... thanks for any help./
---kyle
Old 09-06-2002, 09:36 PM
strodda strodda is offline
washers work fine. i just got longer bolts and added in two washers on each bolt(2 per side). worked pretty damn good for costing under $5. theyre both at about -1/2 a degree.
Old 09-07-2002, 03:44 AM
kicker1_solo's Avatar
kicker1_solo kicker1_solo is offline
Send a message via AIM to kicker1_solo Send a message via Yahoo to kicker1_solo
my friend did the bolt/washer trick on his car, worked perfectly. Here's his how-to on it. Hope that helps.
http://home.earthlink.net/~civicex95/rearcamber.html
if you need any help with it, hit him up on aim at rhtheking
2000 BMW 323IT
1954 Ford F100
With every post my penis grows smaller
Yakima Valley Truck Club Yakima Washington
Old 09-07-2002, 11:55 AM
thanks for all the help guys....i usually dont take the cheap way out on things with my car....but have you heard of anyone having any problems with this over the real thing.
Old 09-07-2002, 01:18 PM
nope, although i dont know anyone that actually paid big bucks for a "real" kit. its not easily adjustable, but the washers cant go wrong.
Old 09-07-2002, 05:33 PM
i know my rear was off like 1.25 degrees in the back...do you know about how many washers that would be...what does one washer=...
Old 09-07-2002, 10:20 PM
here you go, this will tell you how to measure it
http://www.automotiveforums.com/vbulletin/t16284.html
2000 BMW 323IT
1954 Ford F100
Old 09-07-2002, 11:24 PM
the normal rule of thumb is basically one washer per degree. and since youre at 1.25, id say just use one. it wont be perfect, but i think 2 washers would push it positive.
Old 09-12-2002, 07:18 PM
i have heard a bunch of different things on how much each washer equals...i have heard anything from .25 per washer to .5 per washer to 1 per washer. does anyone know for sure how much each washer equals.
Old 09-13-2002, 01:21 AM
when working with such small amounts, variation are possible. im lowered 2", and according to ingalls site thats about a 2.12 degree change. after 2 washers, im now at -.5, so that equates to a tad over .75 per washer.
Old 09-14-2002, 08:44 PM
this shouldnt throw my toe off should it...i will have to drive like 100 miles before i will be able to get it alligned.
Old 09-14-2002, 09:29 PM
it most likely will, it messed up mine big time. its a quick fix, so just wait until you have time to align it, and just add the washers that morning. i dont think 100miles would make a big difference anywas, but it wont help.
2 or 3 washers for rear camber trick? Cackophony Tires and Wheels 7 06-23-2002 10:09 PM
rear camber bolts/washers from home depot RedRacerCivic '88 - '91 Civic | CRX | Wagon | Shuttlee 2 06-17-2002 04:08 AM
Progress rear camber kit?!?!?? strodda Accord/TSX/Accord Hybrid 22 04-08-2002 08:04 AM
Easy rear camber fix ricebooy Accord/TSX/Accord Hybrid 1 04-07-2002 01:26 PM
p11 rear camber alignment kits (eibach vs. ingalls) Nismoboy1 Suspension 4 12-07-2001 02:36 PM
