Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 06-23-2002, 11:16 AM
Cackophony Cackophony is offline
Send a message via AIM to Cackophony
2 or 3 washers for rear camber trick?
I'm about to install some lowering springs on my 92 Civic h/b that will drop the car 2.3 inches. I've read that one washer should be used for each inch dropped when doing the rear camber fix. My question is, since my drop will be very close to 2.5 inches, should I use 2 or 3 washers?
Old 06-23-2002, 11:20 AM
swedish swedish is offline
two washers then a thin one (seriously though)
"One great big festering neon distraction,
I've a suggestion to keep you all occupied.
Learn to swim."
Old 06-23-2002, 11:21 AM
good idea, never though about doing that. Thanks
Old 06-23-2002, 12:09 PM
95civicman 95civicman is offline
or you could put on 2 then use the level and see how far it's off then put on 3 and see how far it's off and go for whichever one is closer.
zc powered 89 CRX SI with some more stuff.
Old 06-23-2002, 04:55 PM
onesojourner's Avatar
onesojourner onesojourner is offline
Send a message via AIM to onesojourner
i have almost a 2 inch drop and i used one
don't like my post
The things you own end up owning you-Tyler Durden
videos
Old 06-23-2002, 04:57 PM
Which would be better, to use one too many washers, or one less then ideal?
Old 06-23-2002, 07:54 PM
CXHatchback's Avatar
CXHatchback CXHatchback is offline
Send a message via ICQ to CXHatchback Send a message via AIM to CXHatchback
2 should be fine, I'm dropped about 3 and it's fine for me.
Old 06-23-2002, 09:09 PM
CivicSiRacer's Avatar
CivicSiRacer CivicSiRacer is offline
Civic Mod
Send a message via ICQ to CivicSiRacer Send a message via AIM to CivicSiRacer
I would suggest 2 washers cause some negative camber is good for cornering. Postive camber (tops of the tires sticking out) is bad for handling.
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes
Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!
Autocross Help Page
Buy my Civic parts!
