About a week ago I had the clutch cover, clutch disc and the clutch release bearing changed on my 95 Accord LX manual. I also changed the Clutch Slave Cylinder, the gasket on the oil pan and the right front Axle shaft piece that goes in the engine. Everything is working fine. No leaks no creaks no nothing...EXCEPT...whenever I pull out of first the cars steering wheel starts to vibrate. Then it goes away when I drive normally. I checked the engine mounts and everything seems to be fine. I went to rotate the tires and aline and balance everything and the vibration won´t go away. Everything that had to be touched was tightened and it still will not go away. The steering wheel never vibrated before. NOTE: The vibration also can be seen and felt on the rearview mirrors and center console.
What can it be??? |
I've had the same problem since i installed my CAI.........no one can help me, i've spent over $1,200.00 trying to fix and diagnose but it's just messing up more stuff
I'm in the market for a 2000 328Ci or 2002 Audi A4 1.8T...after owning 3 honda accords that i knew in and out in different countries...i have finally given up and the new Accord is so dissapointing that i'm going the German route now
***ORIGINAL PUREHONDA.COM MEMBER SINCE JULY 2000***Black 1994 Honda Accord EX*Angel Eye Euro Style Projector Lamp 3 Lens with Black/Clear*PIAA Super Plasma H3 Bulbs*PIAA 1200 Series clear driving lens* S-Type Style Tail Lamp (Carbon)*JDM Spec Black Color Corner Lamp *All Clear corners*Type R Style Grill with Mesh*Red AEM Cold Air intake*Magnaflow Euro Stainless Steel Full CatBack Exhaust System*EIbach Sportline Springs*Koni Adjustable Special D" (Reds) Front Shocks*Koni Adjustable Sports (Yellow) Rear Shocks*17" KMC Unit Chrome*Kumho Ecsta Supra 215/17/45*Indiglo Guage (2 way)*Momo Racing Pedals*Type R Gear Knob*Pioneer DEH-P7200 in dash CD receiver*Kenwood KFC-1687(Fronts)*Infinity Kappa 693.3i (Rear)*Rockford Fosgate Punch 200.4.*CODE Pro 300 alarm system |
jalfaro
with the car in neutral and the wheels shocked crawl under the front and grab a axel and see if it has any movement in any direction.... It sounds like the axel wasn't installed properly and is virbrating.... Make sure to do this in NEUTRAL!!! if its not that
