Old 09-02-2002, 07:50 PM
Drifter To Be Drifter To Be is offline
Raising the RPM range.
How do you raise the RPM range of a engine??
Thanks
Old 09-02-2002, 08:26 PM
ivymike1031 ivymike1031 is offline
Send a message via AIM to ivymike1031 Send a message via Yahoo to ivymike1031
depends on the engine... did you have a particular one in mind?
Come on fhqwhgads. I see you jockin' me. Tryin' to play like... you know me...
Old 09-02-2002, 08:28 PM
K20A
The RSX Type S engine.
Old 09-03-2002, 01:50 AM
b16a3sol b16a3sol is offline
a new set of cams and springs, along with eliminating the rev-limiter by rechipping the ecu will get you a couple hundred revs before your new self-imposed redline. beyond that it takes diving deep into the engine which gets more expensive with each part. how far do you want to go is the other question.
Originally posted by honda720
i would never drive like that thats the pussy way to drive stick
Old 09-03-2002, 05:38 AM
Self's Avatar
Self Self is offline
Send a message via AIM to Self
Cam, valve springs, rockers, new gaskets all over, and most importantly a timing chain, will allow you to raise the RPM range of an engine. How "long" of a cam decides how much power you make and until what RPM you make it.
There's no replacement for displacement...No, not even a turbo.
engine chatter at certain rpm range colo_truck Pick-Up 10 10-30-2004 09:23 PM
rpm range soccmid Prelude 6 05-15-2004 02:22 PM
rpm range xtremegeek03 Riviera 1 04-17-2004 01:02 AM
No power in 4500+ RPM Range darkgh0st Grand Prix 5 02-16-2004 06:40 AM
engine chatter at certain rpm range colo_truck Tacoma 2 10-11-2003 03:33 PM
