Old 02-13-2004, 08:01 AM
darkgh0st darkgh0st is offline
Question No power in 4500+ RPM Range
Car is a 2001 Grand Prix GT 46,000 miles. I plan on hooking into the PCM soon but haven't yet. The problem is in the high RPM band. Accelorates great until it hits the 4500RPM and then just hesitates. At WOT it will make its way to the redline and just stay there at the rev. limiter until I take my foot off the gas. The Low coolent light will come on for a few seconds and then go out again (coolant level is fine). I have a k&N that was recently cleaned, and just changed the fuel filter. I'm concerned that I might have phucked up the PCM with my K&N mod since its now exposed without its stock airbox to live in.
Any ideas??? This is driving me crazy
Old 02-13-2004, 11:36 AM
99_gtp 99_gtp is offline
check your plugs and wires and all connections to them are you pulling any codes from the computer
Old 02-13-2004, 11:41 AM
Havent plugged in yet to check codes. Would codes show up even if the service engine light isn't on?
Old 02-13-2004, 12:21 PM
lakerfan1784 lakerfan1784 is offline
Send a message via AIM to lakerfan1784 Send a message via Yahoo to lakerfan1784
Codes will show up on the scanner if the SES light has come on. The computer stores the codes, and the scanner reads and displays them. If the light has ever come on, there will be a code, unless you have recently disconnected the battery
Old 02-13-2004, 04:13 PM
Ripn12s's Avatar
Ripn12s Ripn12s is offline
Send a message via AIM to Ripn12s
Re: No power in 4500+ RPM Range
So the car is not shifting at WOT in "D" ??
Old 02-16-2004, 06:40 AM
The SES light finally came on over the weekend. I will plug in soon to find out whats going on with it. Thanks for the suggestions so far
