| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
Ok, i got a B16A Engine in my car, i have a Cold air intake, 2.25" Exhaust System With Cat-Back, DC Sports Headers, Ecu Chip, fuel Pressure Regulator, and what it's the next step?? i want to know what else i can put in my engine to run faster!!!!
Thanks for your help.
94 Acura Integra 4 Door, JDM Si-R II B16A 5.4Million Series Engine Swap (170HP Stock), With CTR Camshafts, STR Camgears, Clutch Masters Stage 4, DC Sport Ceramic Header 4-2-1, Exhaust System 2.25" W/Apex-i N1 Cat-Back, AEM Cold Air Intake, ECU Erick Racing 5,800rpm Vtec, B&M Fuel Pressure Regulator, Y21 Code GearBox, 16" Rims W/Yokohama Avs Sports. It's not much but I still can smoke fools. Oh Yeah and Don't forget, I'm Proud Member of Guatemala Streetracing. http://www.gtstreetracing.com
Wow...
That's sure alot of mods. I got none yet on mine. Get some better looking wheels and tires maybe. TURBO?? Don't do heavy body mods. I think it makes car look to aggressive and ugly. Maybe stick on a Carbon Fiber Hood. |
In my opinion your engine is pretty good the way it is. If it was me I'd upgrade the suspension and brakes.
Yup.
Maybe stick some Tokico Adjustable Shocks on those. or try lowering your Civic a little. (like about 1" is enough) don't want to scrape the exhaust.
Some Cam Gears and upgrade your ingnition system, maybe a mild port and polish on your throttle body! Oh and of course get car tuned!
www.velocitytrends.com
mmmmmmmmm i wanna go all motor!! no suspencion, no brakes, i want my engine run faster.
how about Pulleys??? it's that good???
Yeah Pullys sound good.
Cam etc. Try raising the RPM range if you have nothing else.
Pulley's are fine if you have power steering (P/S) as well! Most folks take out there P/S (not recommended if its also your daily driver).
If you do have P/S and of coarse the alternator, Pulley are great because they take alot of stress of the crank. Aftermarket Alterantor Pulley and P/S Pulley are much larger than stock making for less revolution of each unit. So yes pulley are great, but if you only sport an alternator, don't waste your money! www.velocitytrends.com |
And, How about AEM TRUE TIME CAM GEARS??? IT WILL HELP?? HOW MUCH HP'S I WILL GAIN????
THANKS!!
Loose the headers. Start looking into a turbo.
1993 rx7 1994 Civic Ex |
