Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 01-15-2002, 10:48 PM
hondacsi hondacsi is offline
Send a message via AIM to hondacsi
Question What next for my suspension?
I have eibac springs and camber kits. What is next for my suspension? What do i need? What brand should I buy? And how much will it cost me?
Old 01-16-2002, 02:50 AM
texan's Avatar
texan texan is offline
Writer Mod
What car do you have, what is the intended use, and how much do you have to spend? My automatic respsonse is some proper aftermarket shocks, but I can't suggest which ones until you give more info.
'03 Corvette Z06
'99 Prelude SH
Old 01-16-2002, 07:36 AM
Sorry i didn't tell you what car i have. I have a 2000 honda civic si. It is a daily driver but i want the best handling i can get
Old 01-16-2002, 10:27 PM
Noone has an opinion?
Old 01-16-2002, 11:32 PM
texan's Avatar
Writer Mod
Well you didn't mention how much money you were looking to spend, so I was hoping you'd come back with an estimate before I posted again. But no big, here's my thoughts...
If you are looking for serious performance handling, I recommend quality adjustable shocks. Yes the adjustment features can cause some trouble for inexperienced users, but there's always someone you know who should be able to help setup the car for you. And it's not rocket science, you adjust the shocks to cater to whatever use(s) the suspension is being built for. So I would look into Koni Yellow shocks (single adjustable, rebound only) as a good performance match for your springs, and then some quality tires. Tires make more of a difference in handling than any other upgrade, you'll be amazed at the differences in grip and handling if you are still running on stockers. Try for a set of Bridgestone S03's if you like their price, it's what I run and couldn't be happier.
'03 Corvette Z06
'99 Prelude SH
Old 01-17-2002, 07:36 AM
Thanks man koni is kinda what i was lookin for i already have the toyo ts-1 tires and the grip like hell so i think that i am straight on that. So once i get the shocks what else do i need for my suspension? You asked about money, it is a factor but I want to get the right stuff so if I have to save for another month then i will do so.
Old 01-17-2002, 04:05 PM
Drocca91's Avatar
Drocca91 Drocca91 is offline
Send a message via AIM to Drocca91
front and rear strut bars, rear tie, i dont know if you wanna upgrade on the si sway but there is that option and maybe you can get a floor bar.
91' CB7
Old 01-17-2002, 04:26 PM
Thanks guys for the help.
Old 01-17-2002, 05:00 PM
spy54's Avatar
spy54 spy54 is offline
Send a message via AIM to spy54
texan where in soCal are you?
AF Teen Crew
Purehonda.com - may she rest in peace
1996 Chevy C1500, Flowmaster Exhaust, Tinted Windows, 2 Kicker 10" L7 Subs, Eclipse 5v headunit, Alpine V12 Amp
DJM 4/6 drop kit being sold
Full Throttle 9.5 inch lift being installed
1989 CRX si "silver mist"---SOLD---.....Stripped and Wrecked in Compton
corbeau forza 2 seats, DC short shifter, Powerslot slotter rotors, AEM brake pads, Bfgoodridge Stainless steel brake lines, Greddy MX exhaust, AEM Cold Air Intake, Konig Rated-R rims, Kamikazi header
Make an Offer [email protected]
Old 01-17-2002, 07:58 PM
texan's Avatar
Writer Mod
North LA County, near Castaic lake.
'03 Corvette Z06
'99 Prelude SH
Old 01-22-2002, 06:08 PM
PFCfutrell PFCfutrell is offline
Send a message via AIM to PFCfutrell Send a message via Yahoo to PFCfutrell
I highly recommend ditching your factory rear swaybar with a thicker aftermarket unit. Installation isn't that hard and a Suspension Techiniques rear sway bar is only about 150 bucks and it's one of the thickest on the market. A new rear sway bar will definetly cancel a lot of your cars inherent factory understeer giving you a much more neutral cornering attitude. I really like my Tokico Illumina shocks which are 5-way adjustable and would go well with your springs until you upgrade to a coilover sleeve (Ground Control) or a true coilover kit.
1991 CRX SI (black)
15.3 @ 88mph (stock motor)
'90 B18A1 swap
Custom exhaust
*2.25" piping
*two glasspacks (inline)
*polished flash-cut tip
*exits pass. side, front of rear tire.
'95 GSR 15" wheels
195/50/R15 Bridgestone Potenza SO-3's
AE Eng. front crossmember
Susp. Tech. 22mm rear sway bar
Susp. Tech. 1.8" lowering springs
Tokico Illumina 5-way adj. shocks
Powerslot rotors
Metal Master pads
Goodridge steel-braided brake lines
Red painted OEM calipers
Skunk2 short shifter
Skunk2 shift knob
GT Grant steering wheel
Red/black racing seats
