Old 08-31-2002, 12:22 PM
giordano giordano is offline
from one tamiya spray can how...
... many cars can you paint before you run out of it? average? cause when i was spraying my kit i've finished the whole can and i haven't had the chance to paint some of it's accessories. so i have to buy another can to finish it. but the body doesn't have any over spray on it though and it really even. from the tamiya manual it said that the average cars that can be painted is around 3. how is that?
Old 08-31-2002, 12:35 PM
daggerlee's Avatar
Depends on how many coats you put on it and how heavy the coats are. If you get perfect paint jobs, you can often do 2-3 cars from a single can. Perfect paint job typically would be 2-3 mist coats and 1 wet coat. The wet coat would go on smoothly enough that you wouldn't need any other coats. The only purpose extra coats serve is to provide a thick enough paint layer so that you can polish it - but then again, a perfect paint job would require minimal polishing.
Dan
Old 08-31-2002, 06:56 PM
primera man's Avatar
"P-Man"
Ditto to Dan.
I think it sounds like you have bathed your model in paint. To much paint and it will loose its detail.
What Dan said is spot on with painting
View All My Models Here.
Old 08-31-2002, 07:59 PM
well, it's not thick though, cuz the body lines and all small details are still there. so you mean i sniffed some of it?!
Old 08-31-2002, 08:19 PM
daggerlee's Avatar
Tamiya paints are lacquer paints, which go on very thin and smooth generally, so even after a full detail. But if you applied all that paint at once then you will lose detail, if you apply it over a period of coats, you won't.
Dan
Old 08-31-2002, 09:07 PM
JOSE MARIA JOSE MARIA is offline
how to cleanly re-start
If your not happy with your painting, and you want to remove everything , starting from 0.Donīt sand. Buy a litre of break fluid , put it ina container and leave the body inside of it for one or two days. The paint leaves off like a flim without harming any detail of it or the very plastic.
Old 08-31-2002, 09:10 PM
"P-Man"
Re: how to cleanly re-start
I thought brake fluid would eat the plastic away ???
Old 09-02-2002, 12:09 PM
bvia's Avatar
bvia bvia is offline
Talking Re: Re: how to cleanly re-start
Brake fluid has worked fine for me in the past (DOT5), but since I went to Castrol Super Clean, I've never looked back.
hth,
Bill
:bandit:
Bill
"Why yes, that IS my bare, carbon fiber Enzo in Scale Motorsport's "How to Carbon Fiber Decaling video!"
Old 09-02-2002, 12:25 PM
rcmaxx rcmaxx is offline
brake CLEAMER eats plastic.............not FLUID
Tamiya Spray can _835_ Car Modeling 5 12-30-2002 07:11 AM
Cheapest place to get tamiya spray can TheSyndicate Car Modeling 15 12-11-2002 02:39 AM
Tamiya spray cans Gatto Car Modeling 4 08-02-2002 10:39 AM
Tamiya Spray-can question. 306s16 Car Modeling 2 06-17-2002 01:59 AM
Tamiya spray cans Snooker Car Modeling 18 04-16-2002 02:35 PM
