Old 04-16-2002, 09:30 AM
Snooker Snooker is offline
Tamiya spray cans
I sprayed 2 layers of Orange to the body of my Subaru Impreza and the can is nearly empty
What am I doing wrong?
Old 04-16-2002, 09:37 AM
MaxSE's Avatar
MaxSE MaxSE is offline
well what does the body look like?!?!? does it still need more paint?
Say NO to wheel gap...
Old 04-16-2002, 09:41 AM
barnabei's Avatar
barnabei barnabei is offline
You're painting your subaru orange could be the first problem
Just kidding, it'll probly look dope, wouldn't mind seeing some subarus done in other colors than the typical blue, black or silver. Try spraying on a few mist coats first, followed by a heavier coat later to get opaque coverage. You really should check out Guiddy's info on painting. I've only used Tamiya cans to paint the body and by following guiddy's instructions i've been pretty impressed. I find that i have enough paint in those cans to get at least two bodies painted. So yeah, try usin' a little less paint between coats. Hope it turns out alright.
Yes, itīll need 1 or 2 layers of paint. But that cannot be normal nevertheless that I need 1 or 2 spray cans for one kit! Thatīs fīn expensive.
Old 04-16-2002, 09:51 AM
MaxSE's Avatar
well was the body clean before you started spraying it? what i mean is did you prep it well before you applied your first coat? eg. wash in warm water, let it stand for a couple of hours, etc. The reason i'm asking is cause once i sprayed a model that was sitting around the house for years, and i didn't prep it, and i had the same problem, the paint didn't want to "stick". Oh and another thing, is the orange your using lighter than the color of the body? Let me know, cause nomally i can spray 2-3 cars with one can of TS paint.
Old 04-16-2002, 09:54 AM
Well, I took the body out of the box and primmed it. Then I applied the paint (2 coats). The paint sticked well, I think. I sanded the body a little bit and washed it in warm water with soap.
Old 04-16-2002, 10:03 AM
MaxSE's Avatar
how long did you wait between the primer coat and the first paint coat?
Old 04-16-2002, 10:04 AM
20 - 24 hours.
Old 04-16-2002, 10:07 AM
MaxSE's Avatar
And it still doesn't look like it got enough paint??!?!
Old 04-16-2002, 10:10 AM
I didnīt say that. It looked it has enough paint, there were only dust that i sanded away. I will add another coat of paint tonite.
Old 04-16-2002, 10:18 AM
MaxSE's Avatar
OK. well generally a can of tamiya TS paint should last you 2-4 fully covered car bodies. Post some pics, then maybe we can get a better idea of what exacly you're doing.
Old 04-16-2002, 10:21 AM
I donīt have a digital camera. Could the coats be too thick?
Old 04-16-2002, 10:26 AM
MaxSE's Avatar
Well yeah, can you still see the pannel lines?!
Old 04-16-2002, 10:31 AM
Yes, I can. They are nearly like box stock.
Old 04-16-2002, 10:39 AM
MaxSE's Avatar
Well i can't help you anymore, cause i can't think of any other reason why you're using all that paint. I picture would really help if you want a definet answer.
tamiya lotus europa special teszion Completed Projects / Gallery 12 02-05-2012 12:41 AM
