Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 08-28-2002, 03:51 AM
thebobs's Avatar
thebobs thebobs is offline
are my tires gonna wear and tear?
will a -3 degree camber cause extreme tire wear. i have to use zrated low pros cuz my ride is so low. :bonghitte
also i think my toe angles are messed up, cuz my car pulls to the side. by the way its a 98 prelude SH at least 2 "
Do a lot of people experience trouble with the control arms rubbing after camber kit is installed?
Old 08-28-2002, 07:05 AM
HONDA_99 HONDA_99 is offline
yes. and very fast.
you need to get alignment done. and you probably need a camber kit to that -3% camber.
Old 08-28-2002, 08:08 AM
CAptynCrunch CAptynCrunch is offline
No, -3 degrees of camber won't do anyhting to increase tire wear.
IF you corret your toe settings. It isn't camber that kills tires, it's lowering a car and not adjusting the toe settings that kills tires early.
However, Negative camber, while giving better traction through hard cornering will also decrease stability at high(i mean red-line in fifth) speeds in a straight line.
So yeah, go for the alignment job, I mean it's always a good thing no matter what. But a more complete suspension would be nicer.
Keiichi Tsuchiya isn't the drift king,
Michael Schumacher Is.
The only thing better than cars is Music... maybe.
Old 08-28-2002, 12:11 PM
thebobs's Avatar
did u mean to say -3 degrees of camber wont to anything to DECREASE tire wear?
saturn rental cars do WONDERFUL e-brake slides
Old 08-28-2002, 01:09 PM
strodda strodda is offline
thats not true, excessive camber either way WILL increase wear. not as much as bad toe, but it will. bad camber will cause the tires to wear hard on one side. bad toe will cause a feathered affect. i was lowered 2" and after a year the insides were almost bald, and the toe was fine.
you should definetly get a camber kit and get an alignment, asap. and if you wanna save alot since kits can be expensive. just install it yourself and take it the same day to the shop.
Old 08-29-2002, 07:20 AM
CivicSiRacer's Avatar
CivicSiRacer CivicSiRacer is offline
Civic Mod
Send a message via ICQ to CivicSiRacer Send a message via AIM to CivicSiRacer
What? Where'd you hear that one? So if I put a 5" heel on your left foot and a sandal on your right foot you aren't going to have any problems walking?
-3 negative camber is a bit excessive. Even some autocrossers only go up to 2 degrees.
So a combination of toe and camber will make your tires wear out quicker. So you can either 1) buy a camber kit, 2) raise the car up, or 3) just live with buying new tires every 3 months.
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes
Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!
Autocross Help Page
Buy my Civic parts!
Old 08-29-2002, 03:27 PM
thebobs's Avatar
every 3 months?!?!
how do u figure???
Old 08-29-2002, 06:58 PM
delsolsi delsolsi is offline
Its toe that causes excess tire wear, not camber. Get a protractor and look at how little 3 degrees is. From my personal experience, lowered my car but didn't get the toe fixed, the inside inch or so of the tire wore really fast. Fixed the toe, had -2 dergrees of camber the whole tire wore evenly, slighty tilted to the inside but almost imperseveable, by the time the inside was warn the outside was also in need of being replaced. Yes -3 is a bit excessesive and maybe a camber kit would be a good idea, but not because of tire wear.
I also read in Sport Compact Car a couple of years ago when they where doing an alignment on a project car, Civic Si if I rember but I'm not sure, that their agressive toe setting would cause lots of excess tire wear on the street not the camber.
Old 08-31-2002, 09:14 PM
Civic Mod
Originally posted by thebobs
every 3 months?!?!
how do u figure???
That's just a guess-ta-mate. Excessive camber will wear down your tires quick.
Autocross Help Page
Buy my Civic parts!
Old 08-31-2002, 09:17 PM
Civic Mod
You know what I'm not going to argue. You can believe all you want. If my tires couldn't even stand up by themselves with a 2" drop after 5000 miles, then I guess you are right camber has nothing to do with tire wear.
Autocross Help Page
Buy my Civic parts!
Old 09-02-2002, 01:12 AM
thebobs's Avatar
lol....so can someone give me a definative answer please? will -3 degrees of camber increase tire wear or not?
Old 09-02-2002, 10:15 PM
Civic Mod
Email me.
Autocross Help Page
Buy my Civic parts!
Old 09-03-2002, 02:06 AM
yes it will. its not gonna kill your tires in a month, but why would you wanna put unnecessary wear on expensive tires. i sure as hell wouldnt want to. just do what i did, put up a kit. hopefully cheap from ebay or something like that. install it yourself and pay a shop to adjust them. thats alot better than shortening the life on a set of tires thatll probably run you $500+ to replace them.
bottom line. anyone who says excessive camber doesnt affect tire wear, ignore them.
Old 09-03-2002, 07:20 PM
Just for clarification what are you calling "execessive wear" A or B. In my experience A is what you get from camber, I do not call this excessive. B is what you get from toe, this is excessive and your tires wont last as long as they should.
Old 09-04-2002, 01:39 AM
thebobs's Avatar
ok delsol u like to use logic rite? so the fact that 3 degrees is hardly noticable from the naked eye means it wont wear fast right. well consider this logic: for every action there is an opposite and equal reaction. in the case of tires u have a certain surface area pressing a 4th (in the case of one tire) of the weight of the car against the road. Now in the case of normal camber, you would have that weight evenly distributed across the whole tire. Well the fact is, a tire isnt that wide, and a car is fucking heavy, so every little cm displaces some weight. So yes, tilting the tire at even a slight angle, and putting more of that force over a smaller area means the tire is pushing harder on the road, and remeber what i said at the beginning? the road pushes back, oh yes it does, and over that small area it rips rubber off a lot faster.
I suppose that you have shitty tires on your ride, because i could understand a harder tire not taking as excessive wear. But im riding on some soft shit, so i think im going to have to say i dont buy your shit or your diagram.
:finger:
heh
PS2 Wear and tear... CassiesMan Gran Turismo Series 3 04-09-2005 09:40 PM
Superchager, wear and tear? Jep164 Performance 12 01-09-2005 09:10 PM
forced induction: additional wear and tear? mother_russia Forced Induction 4 02-10-2004 05:20 PM
Tire Wear and Tear xterrase Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 5 05-27-2003 02:59 PM
Wear and Tear for Wrangler MT/R's HuNtErX Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 16 05-14-2003 05:07 PM
Closed Thread
