Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 02-05-2004, 09:52 PM
mother_russia mother_russia is offline
forced induction: additional wear and tear?
i am mainly concerned about the turbo charger. does an added turbo charger increase the wear and tear on your previously stock engine? how about a s/c?
Old 02-05-2004, 10:50 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Not really, as long as you lower the compression accordingly, keep the air/fuel mixture in balance, keep the air intake charge cool, maintain the turbo the right way, and make sure to get the car tuned to run in harmony with the new go fast parts you should have a longer lasting engine than if you modded it to run N/A since the engine won't have to work as hard to make the same power. You can also retain good fuel mileage with a turbo.
Old 02-06-2004, 12:07 AM
turbo2nr's Avatar
turbo2nr turbo2nr is offline
Send a message via AIM to turbo2nr
Re: forced induction: additional wear and tear?
with turbo you have to be untop of the maintaince that is key. but like polygon said it wont put to much stress .
1
Shift_BOOST
97 s14
Old 02-06-2004, 12:52 PM
SaabJohan SaabJohan is offline
When power is increased, so is the stress on the engine. However, the increase in stress from a turbocharger is smaller than conventional tuning to increase power.
Old 02-10-2004, 05:20 PM
-Josh-'s Avatar
-Josh- -Josh- is offline
Automotive love doctor
Send a message via AIM to -Josh-
On the safe side though, it's always good to get a forged crank and pistons when adding Forced Induction, be it turbo or S/C. Some engines just aren't made to handle it.
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
