Old 08-28-2002, 03:28 AM
thebobs's Avatar
thebobs thebobs is offline
Angry A Camber Confusion!!!
i just got a 98 prelude SH. its lowered about 2 inches, and i just had the alignment checked. Apparently the tires are out 3 degrees, and the mechanics recommended a camber kit. What am I looking to spend and is the work worth it? Also, does intake/headers/exhaust improve gas mileage?
Old 08-28-2002, 04:52 AM
thebobs's Avatar
i guess i fucked up...
hah well this should be in the suspension section shouldnt it:zx11pisse
saturn rental cars do WONDERFUL e-brake slides
Old 08-28-2002, 10:17 AM
higgimonster's Avatar
higgimonster higgimonster is offline
intake/headers/exhaust allow more air to freely flow into and out of your engine. this extra air will inturn give you a powerboost, but inorder to compensate for the extra air the computer sends more fuel into the engine. this means you actually get less mpg.
I would also say that a camber kit is pretty important. your tires are going to wear unevenly and your traction is much less then it could be. In order for your car to handle correctly your camber needs to be set up corectly.
Promoter of the one line signature.
Old 08-28-2002, 12:30 PM
jimmyfunk's Avatar
jimmyfunk jimmyfunk is offline
Send a message via AIM to jimmyfunk
If you want your tires to last long at all....a camber kit is a must. If you have aftermarket tires...i'm sure you spent some $$ on them and you should try to protect your investment any way possible.
GO BIG PAPA!
aim: XjimmyfunkX
Old 08-28-2002, 12:52 PM
Tominos Tominos is offline
camber kit is 300 bucks and up i believe. if you want your tires to last more than a month, you will want to get it, no use in blowing 400+ on tires only to have to go back and get another set next month.
Old 08-29-2002, 11:55 PM
jimmyfunk's Avatar
you can get a top-of-the-line camber kit (front only for anywhere between 100-200. There's no need to buy a camber kit for the rear because you can fix this safely with washers and bolts for about 7 bucks (instructions in the FAQ). Check out www.thepartstrader.com for a used camber kit. But no matter how you do it....a camber kit is a must.
GO BIG PAPA!
aim: XjimmyfunkX
camber or no camber? alinb Wheels/Tires/Suspension 12 02-06-2007 07:37 PM
Confused with camber kits. Rufes1 '88 - '91 Civic | CRX | Wagon | Shuttlee 21 07-30-2004 02:54 AM
Im SOO confused with this camber kit stuff help!! fyrewyre819 Accord/TSX/Accord Hybrid 6 02-06-2004 06:57 AM
the camber confusion CONTINUES thebobs Tires and Wheels 1 08-29-2002 07:22 AM
camber kit with Pro-kit Eibach springs? IDE RaiD Accord/TSX/Accord Hybrid 3 07-06-2001 06:58 AM
