Go Back   Automotive Forums Car Chat > Honda > Wheels/Tires/Suspension
Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive.
Old 10-30-2006, 07:51 PM
alinb alinb is offline
camber or no camber?
does anyone know if lowering the front of a 05 accord 2" reqire a camber kit? i've read that hondas are good about not needing them. i don't mind a slight not normal wearing as long as it's not too bad.
Old 10-31-2006, 02:18 PM
LVApex's Avatar
LVApex LVApex is offline
Re: camber or no camber?
I would argue that even a Stock Accord should have a camber kit, Simply to be able to get away from the craptackular OEM alignment spec's. (OEM alignments hamper the cars ablility to turn)
As far as tire wear... Bad toe settings will eat tires 10X faster then just about any amount of camber. So as long as you get the cars toe aligned you should be fine.
Old 11-01-2006, 06:50 AM
thanks i glad to here that...
Old 11-01-2006, 06:41 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Some negative camber is actually better for turning....
Old 01-26-2007, 12:15 AM
chivid chivid is offline
the road is not exactly flat so each car is designed with camber stock to keep it even on the road.
Old 01-26-2007, 05:19 AM
Kind of a Big Deal
right, but if you look at your tires when turning, they actually have positive camber, so a little negative camber helps counteract that and keep a larger contact patch on the ground when cornering.
Old 01-26-2007, 11:23 PM
you notice that the BMW have negative camber on the wheels? you need a lil bit of camber on your car. This was said to me from the shops i taken my car in for alignment. three different shops told me the same exact thing.
Old 02-02-2007, 04:24 PM
LVApex's Avatar
I would say more then some... -1 to -1.5 on a daily driven street car with Allseason or your average summer tire would probably be near optimum. 2- or more would be needed for a car used for compitition given the tires used.
I actually run -2.5 deg camber on the nose of my civic, which is used for autocross.
The idea with adding static negitive camber is to make your tire Flat on the ground when your suspension is at full compression... The idea is you are giving your tires the maximum amount of contact patch at the moment it needs it most.
Old 02-02-2007, 07:27 PM
Kind of a Big Deal
ok... so what would you recommend for my car? 93 ex daily driver but is also going to be a weekend warrior.... and i dont mind sacrificing a little tire life.
Old 02-06-2007, 11:57 AM
LVApex's Avatar
... I would probably start between -1.5 and -2 deg on the nose, and probably -.5 to -1 on the rear. Then run 1/32nd toe out on the front, and 0 toe on the rear, then adjust rear toe to tweak the cars oversteer understeer balance. (Toe in to make the car oversteer less, toe out to make it oversteer more)
Old 02-06-2007, 03:07 PM
Kind of a Big Deal
wont toe out cause the car to be unstable on everyday road surfaces? I thought factory toe settings were set a little in to make the car pull less over uneven road surfaces.
Old 02-06-2007, 04:24 PM
LVApex's Avatar
Toe out on the nose is to help the car initiate turns... I.e. Turn in responsiveness will improve. And yes, it will tend to make the car want to wander a bit while driving in straight lines. however, 1/32nd total toe out isnt a whole lot... thats 1/64th of an inch toe out per side... so its there more to compensate for bushing compliance then to help the car turn (a FWD car will naturally want to toe in under acceleration, so dialing in a little toe out compensates for this)
Old 02-06-2007, 07:37 PM
Kind of a Big Deal
ahh, thnx for the info, good stuff
