Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 08-27-2002, 10:08 AM
mikerez mikerez is offline
Send a message via AIM to mikerez Send a message via Yahoo to mikerez
Proper Way to Slip Clutch?
Hello All,
I've been driving stick-shifts for several years now and am not a newbie to 5-speeds. However, I was wondering if anyone can offer up some suggestions as to the best way to shift gears on the 2002 330Ci?
I always match RPMs in 1st gear
Usually match in 2nd
And rearly match in 3-5 (unless accelerating hard)
However, it seems like I have to slowly slip the clutch into gear or the car will bob and jerk. I'm just a little worried that riding the clutch too much might cause un-needed ware.
Also, I've found that giving just a bit of gas when shifting in the upper gears does help a lot with a smooth transition, however I always thought that you shouldn't have to "double clutch" if not driving hard.
Any thoughts?
2001 Audi TT 225 6spd
2003 VW Jetta GLS 1.8t 5spd
Old 03-05-2004, 10:34 PM
turboman318 turboman318 is offline
Send a message via AIM to turboman318
Re: Proper Way to Slip Clutch?
in the lower gears it's always more "sensitive" when making gear changes driving normally. to get that smooth shifting effect you have to "slip" the clutch which is normal.
00 Eclipse GT (115k mi) Clutch Question Stock00ClipseGT Eclipse 2000+ 3 11-26-2010 02:39 PM
Proper Way to use Tamiya Compound/Wax? Camber Car Modeling 2 11-29-2002 03:17 AM
proper way to store civic CustomBlackCivic96 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 12 09-08-2002 01:18 AM
Does anyone know proper way to bleed brakes on P11 and proper break-in on new pads?? ty423 Maintenance 5 03-02-2002 07:51 PM
proper way to launch? Quetzolcotl '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 9 02-18-2002 01:38 PM
