Old 08-25-2002, 03:35 PM
89Civic 89Civic is offline
Send a message via Yahoo to 89Civic
Need Help ASAP Please
I'm trying to remove the coilover/strut assembly so I can remove the upper control arm on my '89 honda civic. So far I have all but 2 bolts out. I'm having trouble getting the pinch bolt out on the coilover/strut and can't get the bolt out on the bottom of the fork. I got the nut off but it's not sliding through and I tried to screw it out but it's not going any where...just spins with tension. Any ideas? Thanks in advance.
Paul
'89 Honda Civic
Old 08-25-2002, 04:00 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
Ok take ur socket and put a pipe over the end of it, that gives you more leverage and increases the force on the bolt. Also lube it up with some anti-seize such as PB Blaster. I PB'ed my bolts and use the socket with pipe over it and it worked fine. Also if you have a 1/2 drive long handle that would work just as good to. I did PB and a pipe over the socket and had no problems with mine.
As a rule when I do things on bolts that were hard to get out, I soak them in WD40 before I put them back in because chances are I may be taking it off soon again.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 08-25-2002, 04:52 PM
BullShifter's Avatar
Use an impact gun
Old 08-25-2002, 05:17 PM
if I had a impact gun don't you think i'd of used it already??
Paul
'89 Honda Civic
need help asap please help atv087 Eighty Eight 2 08-31-2005 03:17 PM
Need Help Asap Please!!!!!! crx-treme JDM Motor & Parts info/chat 6 04-12-2005 02:51 AM
dakota wont start need help asap please!!!! 98whitegpgt Dakota 10 11-25-2004 07:33 PM
need help asap.. please CivicWarrior '88 - '91 Civic | CRX | Wagon | Shuttlee 5 08-24-2004 06:31 PM
need help asap please aces1980 '88 - '91 Civic | CRX | Wagon | Shuttlee 11 11-05-2003 04:59 AM
