Old 11-03-2003, 05:45 PM
aces1980 aces1980 is offline
need help asap please
i need to change my timing belt and am having trouble with the crankshaft is there a way to lock it up so that it does not turn. or am i going about it all the wrong way. pics will help too. thanks in advance.
Old 11-03-2003, 06:40 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
there should be an adjuster gear that you can move to release tension on the belt to spin it off.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 11-03-2003, 08:03 PM
Re: need help asap please
But in order to get there i have to remove the crank pulley so that i can get to the shield or what ever that thing is called. Is there any way to lock it up?? a special tool or something?
Old 11-03-2003, 08:45 PM
i_a_n112784 i_a_n112784 is offline
Send a message via AIM to i_a_n112784
use a punch, or a large screw-driver to shove through a hole on the pulley, unless you have a solid one, and that will stop its rotation. If you have an impact wrench, you normally dont need to block it like this. (I LOVE my impact, and hate thinking about all the manual labor i'd be doing without it).
Old 11-03-2003, 09:03 PM
Dumped91Hatch's Avatar
Dumped91Hatch Dumped91Hatch is offline
Yeah life is much eaiser with the trusty ol impact. you could drill a hole in the pulley if it is solid and use the screwdriver idea. Good luck
Check out my car here My 91 Hatch
Old 11-03-2003, 10:09 PM
well that is the thing i am using a impact gun with 120psi and it is still nothing. I am running out of ideas.
Old 11-04-2003, 03:33 PM
Wow, that sucks.. If you've stopped the spinning, and it just wont come loose, try spraying it with penetrating oil (WD-40 would work), let that soak in, try again. If that doesn't work, try using a large breaker-bar and maybe a pipe or something to get more torque than the impact can get.
And I bet when you get that out some dumbass used lock-tight on the threads, which is stupid because the engine's turning tightens the bolt down and keeps it torqued
Old 11-04-2003, 04:34 PM
crxlvr's Avatar
yea, like these other guys my 600ft/lb impact gun got it off quick.
but without removing the tranny to get to the other side, i cant think of a simple way you can do this.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 11-04-2003, 07:13 PM
ok well now we tried a 800ft/lb impact gun and nothing. i am really mad at my car right now????? any other suggestions
Old 11-04-2003, 07:27 PM
Well, you can't heat it, seeing as it would be useless. You're not going to get more torque than that unless you use a 3/4" impact. I'd be seriously considering making it someone else's problem by taking it somewhere.
I had to get out the 3/4" impact on one of those bolts, and the 1700 lb-ft of torque didn't do much, until the head of the bolt snapped clean off. That caused alot more work than I ever want to do for a timing belt again.....
Old 11-04-2003, 07:28 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Put something through the flywheel to hold it in place ?
Old 11-05-2003, 04:59 AM
well i finally took it out after two very long days of work. I now have another problem, all i did was change the timing belt and now it is miss firing in sprak plug #1 well i have spark but no fuel is getting to it. Any ideas of what it can be?
need help asap please help atv087 Eighty Eight 2 08-31-2005 03:17 PM
Need Help Asap Please!!!!!! crx-treme JDM Motor & Parts info/chat 6 04-12-2005 02:51 AM
dakota wont start need help asap please!!!! 98whitegpgt Dakota 10 11-25-2004 07:33 PM
need help asap.. please CivicWarrior '88 - '91 Civic | CRX | Wagon | Shuttlee 5 08-24-2004 06:31 PM
Need Help ASAP Please 89Civic '88 - '91 Civic | CRX | Wagon | Shuttlee 3 08-25-2002 05:17 PM
