Go Back   Automotive Forums Car Chat > BMW > 5 Series
Old 08-24-2002, 07:48 PM
tdiesel tdiesel is offline
Question 89 525I blower resistor pack
I have a 1989 525I and have been having trouble with my AC blower.It only works on Hi speed. I purchased a new blower motor resistor from the dealer and cannot seem to find out where exactly its located to replace it. I looked in the obvious places: around the blower motor itself, and from inside the car on the driver and pass side.
Any help on this would be appreciated.
Thanks
Old 09-09-2002, 07:36 PM
LarryBrown LarryBrown is offline
Question Blower motor resistor pack-check the control panel
Check the control panel near the faulty side's fan control. The wheel operates a resistor that controls the fan's speed. If you feel a notch at the "hi" end of the travel when operating the wheel, the purpose of that notch is to mechanically short out the juice directly to the blower motor, effectively by-passing the rheostat mechanism. That's why the switch works on high even with a defective rheostat. So check the control panel for the faulty component.
Old 09-12-2002, 10:00 PM
jvan_denburg jvan_denburg is offline
Resistor pack
I just replaced my resistor pack and it fixed the same problem. On the driver's side of the center console, just above the gas pedal, there is a single screw holding a carpet panel to the console. Take that out. I found out after the fact that I did NOT need to remove the pedal cluster trim panel, even though it helped me see things.
The resistor pack is located behind everything in the center console, kind of where the floor meets the firewall. There is a 4-wire(?) plug leading in to it. If you don't take the trim panel out, you kind of have to go by feel.
Good luck.
Old 01-11-2006, 03:32 PM
bump0122 bump0122 is offline
Re: 89 525I blower resistor pack
there is a very helpful web page with detailed steps for replacing the resistor along with pictures. site is: bmwe34.net
Blower Resistor Mounting Problem silverado_04 Silverado 3 08-09-2010 08:08 PM
Blower Motor Resistor Pack jarhed323 Silverado 13 12-14-2009 05:47 PM
97 Malibu blower motor resistor pack location crengineer Malibu 1 12-17-2007 06:27 PM
Heater blower resistor pack needs replaced ksflatfoot Caravan | Voyager 2 03-05-2005 07:25 PM
Resistor Pack Question for A/C Blower Motor eibrown Taurus | Taurus Wagon 1 10-24-2004 08:31 PM
