Old 01-17-2008, 07:52 AM
jarhed323 jarhed323 is offline
Blower Motor Resistor Pack
Hey all...I just wanted to share a few quick pictures of what I believe to be a problem with many chevrolet vehicles (this is the 3rd one I'm aware of happening to) and the blower motor resistor pack.
It seems that the pack gets so hot, it litteraly burns itself up, leaving burn marks on the board. I've had it happen on a late 90's model pickup, a 2002, and now a 2004...What gives?
Anywho, here are the pictures.
Old 01-17-2008, 10:27 AM
j cAT j cAT is offline
Re: Blower Motor Resistor Pack
i had this problem on 2000 sil the cabin air filter got too dirty restricted air flow and the circuit runs on board got hot which then caused the protective coating to lift then moisture finished it .on installing new resister module i coated the module better than original with circuit board coating spray . and keep the cabin air filter and windshield
air inlet grille clean, snow blocking air inlet screen will damage this part. it is possible to repair this part if you are skilled in this type of work......
Old 01-17-2008, 11:06 AM
thanks for the input j cAT, i might just give that a try...unfortunately, I won't know whether or not it works until god only knows when.
ciao!
Old 01-18-2008, 12:21 PM
gremlin96 gremlin96 is offline
i can not see the borad well. if the photo could show it better i mite be able to tell you what to replace to get it working. the easyest way would be to replace all componits with higer rated ones. and add fuses in line.
Old 01-18-2008, 03:55 PM
the runs on the board are resistive in nature, this is the speed control , as in the past the wire resistors worked perfectly, so GM decided to screw up a solid design.......wire resistors can be substituted for the runs, using the same board , or mod old style, to work with this mount in the air box. the heat because of lack of air flow, not current causes the runs to fail........
Old 01-19-2008, 10:26 AM
we can make it cheaper and faster. now the guy who buys the truck gets it in the end. the traces are not made to take the years of heat. so thay end up lifting and burning.
Old 12-06-2009, 07:28 AM
SilveraDon SilveraDon is offline
Also missing blower speeds on 94 Silverado and bought replacement resistor pack. Don't laugh, but WHERE does it go? I removed the glovebox but have not seen a way to get further into the blower housing. The Haynes manual doesn't depict this area very well.
Old 12-07-2009, 12:47 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
The resistor pack is actually screwed to the side of the blower motor casing...might be easier to get at from under the dash instead of through the glovebox opening. Hope you were good at Twister when you were young...good luck!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 12-08-2009, 07:10 PM
Thanks jdmccright - I'll tackle it again this weekend. When I tried it before, hanging half in / half out the door, it started to rain so I buttoned it back up and just lived with it for past few months. AC's got a new compressor that blows really cold so I shouldn't complain too much. Yeah, two weeks away from Xmas and we're still needing AC here in FL...
Old 12-13-2009, 10:47 AM
I've just spent 30 min trying to look under the dash. There doesn't appear any space at all between the inside of the firewall and the heater blower assy on the whole righthand side. It goes right up to the firewall. Tried looking over towards the driver's side and although there are a few places I can see the firewall and backside of the dashboard I didn't see anything resembling my resistor pack. Any further ideas or advice? Thanks again.
Old 12-13-2009, 01:32 PM
what is the year and model new old body style ?
Old 12-13-2009, 06:00 PM
1994 Silverado 3/4 ton Extended Cab with 7.4L V8. I don't know what you mean by new and old body style. Dad pulled a 22' trailer around the country including two R/T CA-FL trips and we drove it here to FL when he passed. Despite all that its still just under 60K mi. I only use it for trips to Home Depot and the occasional trip to Orlando. Thx for any guidance!
Old 12-14-2009, 09:00 AM
intimadatorsquizz intimadatorsquizz is offline
the resistor is #6 in the picture.1994 model years had 3 and 4 speed fans you'll need to know that when getting a resistor.
Old 12-14-2009, 05:47 PM
Thanks to everyone who contributed!! I just got it changed and it works!! Once I found the resistor pack behind 4 relays on a bracket right on top of the duct directly behind the glovebox, I realized it was different than the spare I'd purchased months ago. I took my part(s) back to Advance Auto and they exchanged for the right one. What a BEAR it was to remove and replace!!! Apparently Adv Auto's database had "with" and "w/o" A/C reversed - that's why the first part they gave me was wrong. The fan actually has 5 speeds - Lo, Med, Hi, but there's also Lo-Med and Med-Hi in between the main 3 speeds. Thanks again all.
