Old 03-03-2005, 06:36 PM
ksflatfoot ksflatfoot is offline
Heater blower resistor pack needs replaced
I have a 98 Dodge Caravan. I need to replace the resistor pack. I can see the front of it sticking out of the firewall on the passenger side. I just cannot figure out how to get to the interior side under the dash. I took the glove box out tonight, but cannot see how to get through the mangle of other misc. vents, doors, hatches and plates. Somewhere on this forum I read where someone hit on the process, but cannot find it again. Does anyone know? I could take it to a shop and may be better off in the long run, but thought I would give it a try. Thanks.
Old 03-03-2005, 07:34 PM
vipergg vipergg is offline
Re: Heater blower resistor pack needs replaced
From the manual
Locate and remove connector from the resistor block located at the back of the engine comparment on the passenger side . Remove block by inserting a flat blade pry tool on the side of the resistor block and push inward. 2 guide lines are shown on the right hand edge of the resistor blocks to help guide the blade position .This will release the clip that holds the block in place , pull out block . Install is reverse of removal . you should not have to do anything from inside the vehicle . Hopefully the connector did not melt which sometimes they can , observe the block and connector carefully when you remove the block .
Old 03-05-2005, 07:25 PM
Re: Re: Heater blower resistor pack needs replaced
Originally Posted by vipergg
From the manual
Thank you very much for your help vipergg. Worked out great! The new one is a little loose, but everything works. I suppose I may have squeezed the clips a little too much being the reason the unit doesn't fit snug. I am really glad there is nothing in the way of standing on my head under the dash. That kind of work is hard for a fat boy like me.
Thanks much.
