Old 08-24-2002, 12:22 PM
GTRRR GTRRR is offline
Help before I start.....
I have purchased all my paints and equipment and I am just about to start my S13 SIlvia Model. I need to know a few things before I start.
Do I sand down the primer after every coat, I am guessing it will get very thick?
Can I polish off excess paint from painting panel lines if the body is painted with Tamiya Enamel?
How can I lower the Silvia?
Do I paint the outside or inside of the head/tail lights?
Do I use primer on the interior and underneath the car?
Thanks a lot for all your help guys and I will show you when i'm done.
Got Boost?
Old 08-24-2002, 01:12 PM
flyonthewall's Avatar
Car Mod guy
1- Just give the primer a light sand before applying the top coat. It won't be thick unless u plaster your model with the stuff! A light coat with a couple of heavier ones is fine, although u may notice mold lines that need removing, in which case u will need to sand these then apply more primer.
2- ???
3- Now correct me if i'm wrong but as far as i know your Tamiya Silvia shares alot of its chassis parts with the 180sx. I did one some years ago and now completely reworking it but these pics show what i did;
Lowering the front i quite simple, just remove the top of the front springs and rebuild the locator pin from a piece of plastic rod or stretched sprue. You will also need to extend the connector for the steering arm. Mine was more of an experiment in completly rebuilding the suspension with reals springs, but there is no real need to go to such trouble.
You will also need to add a spacer for your now shortened spring.
I never lowered the rear when i first built this, but the simplest way to lower this complex set up is to remove the horseshoe shaped locator for the hubs. Cut this away and then you can simply glue the hub further up but take care with positioning it right or you will end up with a wheel off the ground.
4- Painting the inside looks alot better.
5- Thats up to you? Personally i prefer to prime everything for a better finish and i would recommend you to do so too.
1996 Jeep Cherokee Won't Start mocojpo2003 Cherokee 16 09-14-2011 03:39 PM
99 Suburban starting problem Please help before I roll this thing off a cliff rtryrktrx7 Suburban 5 03-08-2006 11:46 PM
sputering before starting??? help crxsirpr '88 - '91 Civic | CRX | Wagon | Shuttlee 3 02-21-2004 11:47 PM
Car cranks for ever before starting, any clues? Timbers Intrigue 1 02-14-2004 11:38 PM
87 shadow flooding before starting HELP danefi2 General Discussion 2 02-09-2004 10:31 AM
