Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 03-01-2006, 03:22 PM
rtryrktrx7 rtryrktrx7 is offline
99 Suburban starting problem Please help before I roll this thing off a cliff
99 Burb.
Mileage 62k
Basic problem - it won't start (requires jump)
Common resolutions I've gone through.
Loose cables - side mounts are a poor design. Tighten bolts keep an eye out on these getting loose again.
Corrosion - replace bolts.
Cable mount worn down/won't stay tight - replace battery cables.
Bad battery - Replace battery.
Possible amp draw from starter - Replace starter.
Last week is when I replaced the battery and starter. It started for a week, and began to not start again. I have no idea where to look now. There has got to be a draw on the battery some where. I've been charging it at night. When I get home I'll turn it off, and then look at the volts. In the morning before I try to start it the volts are less. WTF! The alternator shows 14 when the truck is running.
Is there something else I should check that could be causing this. Can the dealer hook this thing to a computer and determine what's killing the battery? I'm close to giving up. The wife already has. She wants a new truck, but I hate to since it's paid off, and only has 62k on it.
A side from this problem the alternator wen out a little over a year ago.
Thanks!
Old 03-01-2006, 03:36 PM
Re: 99 Suburban starting problem Please help before I roll this thing off a cliff
If this works I will kick my own a$$.
I read on here some guy found out parking on a slope drained the battery because of the mercury switch under the hood. I park on a sloped driveway.
I'm not completely sold on this though, because when I pop the hood I have to open the hood about half way before the light comes on.
I'll give this a shot, but please if you have any other ideas I'm trying anything.
Old 03-01-2006, 04:44 PM
2000CAYukon 2000CAYukon is offline
You could pull the fuse for the hood light to see if that is your problem.
This is an interesting article on testing for current drains: http://www.mightyautoparts.com/pdf/articles/tt63.pdf
You need an ammeter for their method but it could help you pinpoint the drain.
//2000CAYukon
Old 03-06-2006, 11:48 AM
I pulled the hood lamp Wednesday after work, and so far I haven't had to charge the battery. I have a question though. This maybe normal.
When I get in the burb in the morning after sitting all night. I turn the key to accessory to see what the battery is showing. The gauge shows barely one line past red. I can start it, for like 10 seconds and kill it. Then turn the the key to accessory again, and it will read two or a little more lines past red. Is that a sign that the battery was low. Of course when I start it it reads 14. BTW, how does this gauge read? You got 9 and several lines then 14, then several lines then 19. What do the lines represent?
BTW, thanks for the link, I've got a meter, so I just might try that next.
Thanks!
Old 03-06-2006, 03:04 PM
The gauge in the dash may not be that accurate until it warms up. Even then it might not be that accurate. I would put a meter directly on the battery to see what the voltage is after it sits overnight.
You could also leave the fuse out for a while and see if things are working properly.
//2000CAYukon
Old 03-08-2006, 11:46 PM
Tuffdrvr88 Tuffdrvr88 is offline
Send a message via Yahoo to Tuffdrvr88
When you start the car the alternator automatically starts refilling the battery's juice which you used to start the car, after the battery is full you are running on A/C current. Did you have the alternator tested? If it is stuck open the alternator can drain your battery over night easily. Let us know.
