Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 08-23-2002, 11:46 AM
srlewis srlewis is offline
Oil change, 1999 Oldsmobile Intrigue
Where is the oil filter located on the 3.5 litre engine in my 1999 Olds Intrigue? Is it a spin-on type filter or a paper filter that fits in a canister?
Thanks!
Old 09-28-2003, 05:52 PM
busboy4 busboy4 is offline
Re: Oil change, 1999 Oldsmobile Intrigue
Your filter, like mine, is a canister type. On the bottom of the oil pan is a "star" shaped plastic canister that you spin off. Inside is the canister oil filter. No big deal to change, just different and more expensive.
Old 09-29-2003, 07:26 AM
beaner beaner is offline
How do you get the canister off?
I've looked at it under the car a couple of times and it doesn't seem like a normal oil filter wrench would fit it.
Is there a special tool needed?
Thanks!
Old 09-29-2003, 07:58 AM
I use an oil filter cap wrench "A". It is an inexpensive circular oil filter wrench designed to fit over the end of a conventional oil filter. It has a 3/8 drive socket hole and fits my '99 Intrigue 3.5L cap perfectly.
Have fun!
Old 09-29-2003, 08:22 AM
Thanks for the info.
I will try that.
One other question... is there alot of oil present when you take off the cap, similar to when you remove a screw-on filter?
Old 09-29-2003, 03:43 PM
As I recall - only done the change twice now - Not a ton. The canister is an open cylinder at the top with the filter inside. There is oil in the canister, so you will not want to tip it until it is clear of the pan and then you can pour it into your container. You will have some running down your arm but not all that much as I recall.
As I said in an earlier post, the biggest deal is that the canister types are not cheap. I think the best I have done is just under $7.00. If you find them for less buy a few.
One other question for you, are you affiliated with NWA?
Old 10-03-2003, 09:30 PM
illinoiswronski illinoiswronski is offline
Shop around. One Auto Zone by my house charges $9.00 for a filter. The other one is $3.99 for the same thing.
Old 06-07-2006, 05:19 AM
edzwrench edzwrench is offline
Found an oil filter cup wrench that works great. Got it from Advance Auto parts. Cost about $5. AmPro # T70401 74/76mm 15 flutes
Old 06-07-2006, 09:11 AM
dtownfb dtownfb is offline
Thanks for the oil filter wrench part number!
Old 06-09-2006, 09:59 AM
LittleHoov's Avatar
LittleHoov LittleHoov is offline
Send a message via AIM to LittleHoov
i didnt have much luck with the wrenches that fit both 74 and 76, the 74 portion was too far up to catch on the one i used.
If that one doesnt work i can get you a part # for one that will, but i special ordered it and i think it was like 9 bucks or something?
Old 06-09-2006, 10:17 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Your info sounds very helpful and will benefit someone on the forum. However, in the future please do not resurrect threads that are this old. The post prior to yours was back in October 2003. It is recommended to start a new post and you can reference to the post you are referring to via a link. Thank you for your cooperation.
Excerpt from AF Community Rules:
POSTING IN CLOSED OR OUTDATED THREADS:
If a thread has been closed, there is probably a logical reason for it. If you feel that the reason(s) for closure of the original thread are unjustified or wish further clarification feel free to contact any member of the moderating team. However, do not start a new thread about another closed thread.
Please avoid posting or voting in outdated threads. It merely clutters up the message board and makes it more difficult for fellow members to sort through the vast amount of information contained on the boards. If you have new and important information to add regarding a past discussion, feel free to start a new thread.
Timeslip 08/12/06
AF Community Guidelines
Mechanic Oil Change Mishap parkca01 Engineering/ Technical 7 01-21-2011 05:26 PM
99.5 Jetta overheating after oil change kate_m '97 - '03 1 03-27-2010 11:06 AM
1999 oldsmobile intrigue/stalling buck1955 Intrigue 4 11-19-2007 06:53 PM
1999 oldsmobile intrigue/security light buck1955 Intrigue 1 11-16-2007 05:32 PM
1st oil change 1999 What oil do you use? Chango Taurus | Taurus Wagon 15 06-05-2007 12:06 PM
Closed Thread
